Black paint to match fender wells?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Simms65, Jan 4, 2016.
  1. Jan 4, 2016 at 7:44 AM
    Simms65
    Simms65 [OP] Well-Known Member
    David
    WV
    '16 Quicksand O/R M/T
    I'm gonna paint the chrome hardware and chrome bumper pieces on my OR. Does anyone know what type of paint I could use which will closely match the finish and texture of the plastic fender wells?
    Thanks!
    McDerper likes this.
  2. Jan 5, 2016 at 6:11 AM
    Simms65
    David
    WV
    Bueller?
    Someone here has to know more than me about paint. :bananadead:
  3. Jan 5, 2016 at 5:12 PM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    No paint can essentially match the exact look of textured plastic. Likely a wrap would be the best option because you can buy that with a texture to it at times. Paint with a clear is gloss which won't be the same look. I am going to paint or buy the rear bumper pieces to colour match and wait to see what grill options pop up. I suspect a nice new TRD pro when it get released will be my choice. If not Bamf's is looking the nicest so far. Then just colour match the chrome trim to your truck, not black to slim down the grill size a bit. /imo
    Last result would be a plasti-dip from a can because it never goes on smooth "ish" but won't be a long term solution.
  4. Jan 5, 2016 at 5:15 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I would use Rustoleum bedliner rattle can paint.
  5. Jan 5, 2016 at 5:16 PM
    ale214
    ale214 Well-Known Member
    Chatham, IL
    2016 OR 4x4 White
    I was hoping to plasti dip my bumper black this past weekend but Lowes was out. I think that will be ok until more bumpers come out. Plus it's cheap.
  6. Jan 5, 2016 at 5:16 PM
    T4RFTMFW
    .. clear coat is available in multiple sheens. Including flat/matte clear.
  7. Jan 5, 2016 at 5:17 PM
    T4RFTMFW
    Also you'll want to sand the shit out of your chrome pieces and use a quality etching primer before you squirt paint.
    Make sure you prep the surfaces well.
    ODNAREM likes this.
  8. Jan 5, 2016 at 5:44 PM
    Simms65
    David
    WV
    I was thinking the higher grade Rustoleum that's a medium finish, not matte, not gloss would match pretty well. I'm gonna take the bumper pieces off and probably media blast them before paint. If they fit in my ovens I might Cerakote them.
  9. Jan 5, 2016 at 5:45 PM
    T4RFTMFW
    Blasting is the better option if you have access to that, go nuts.
    Look forward to pics.
  10. Jan 5, 2016 at 5:47 PM
    Simms65
    David
    WV
    I have a pretty standard sized blasting cabinet, so it's gonna be a tight fit. The grill is gonna be the worst part. I'm not sure what I'm gonna do with it.
    What's everyone doing for re-applying the decals? Cutting two sided tape, getting extra tape from dealers...?
  11. Jan 5, 2016 at 5:48 PM
    ale214
    Chatham, IL
    2016 OR 4x4 White
    Cerakote is an interesting idea. Duracoat might be a little easier to touch up if needed though.
  12. Jan 5, 2016 at 5:50 PM
    Simms65
    David
    WV
    The parts simply won't fit in the ovens I have. Otherwise I'd really consider it.
