Black Plastic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12PM4X4OR, Sep 22, 2013.
  1. Sep 23, 2013 at 6:59 PM
    #41
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    A piece of cardboard makes a decent insulator. It'll keep the hot air from impacting the paint, and as long as you let it cool every so often, it won't transfer much heat from contact... the cardboard will burn before you damage the paint.
  2. Sep 23, 2013 at 9:14 PM
    #42
    DannyD
    DannyD Well-Known Member
    Dan
    BC Canada
    2021 DCLB
    The plastics going dull are actually a result of the plastic being scratched(dirt, washing etc.) and probly some UV damage. Just like any surface the scratches and polishing mean how much shine it has. The heat is actually melting the top layer of plastic creating a brand new layer. So it will last untill it gets scuffed up again. This is why a solvent also works, it melts the top layer but with far less control then a heat gun.
    Theres a hundred videos on youtube about it. Works really well for dirt bike fenders that get bent and beat up, turns them brand new
  3. Sep 24, 2013 at 11:55 AM
    #43
    12PM4X4OR
    12PM4X4OR [OP] Nip it in the bud!
    Fife
    Wanna wax the steps @ the old folks home?
    none
    Thanks Rich/Dan. I'll keep your info filed incase I ever decide to go the heat gun route.
  4. Sep 24, 2013 at 12:57 PM
    #44
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    My bone to pick with Mcguiers Back to Black is that it shows rain run marks when the truck gets rained on after the dressing has been on. it also attracts pollen and dust like a mf'er
    from Detailers Domain i have purchased and used both
    Chemical Guys Black on Black
    Chemical Guys Silk Shine Dressing & Protectant
    I have been using the Silk, ive prob needed to put it on two or three times since i placed the order in May of this year. It doesn't leave an oily residue so when it rains it doesn't leave run marks and it doesn't attract dust and dirt like the off the shelf stuff...
    the verdict is still out since ive only had it for 4 months as far as long term effects. becuase its very different than back to black as far as its chemical make up, its 'dry' and satin finish. im watching carefully for a chemical build up... if and when that does happen i will have to figure out a way to 'clean' the plastic and kind of start over. but i haven't seen any evidence of that.
    the black on black spray is def best suited for occasional engine bay... not fenders / exterior trim.
  5. Sep 24, 2013 at 1:01 PM
    #45
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Griot's has a product very similar to this as well. It works like dye so you have to mask off surrounding areas that you don't want black. It will last years without fading from the experience I have had with the product.
  6. Sep 24, 2013 at 1:05 PM
    #46
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    Only if you are an oxycontin eating backwoods redneck..Who only drives a truck to compensate for the lack of actual confidence in his manhood?
    Otherwise protect your investment. :D
    -Op I would look into that type of paint that forms a molecular bond with with plastic. I was thinking of researching that for my own trim.
  7. Sep 24, 2013 at 1:18 PM
    #47
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Tire shine works great for me, seems to hold up real well and protects it too.
  8. Sep 24, 2013 at 2:54 PM
    #48
    DavisBladeWorks
    DavisBladeWorks Well-Known Member
    North ATL
    2013 DSCB TRD Sport 4x4
    I'd be wary of that. Most consumer grade tire shines have pretty powerful solvents in them. I'd be worried about severely weakening the plastic over time.
  9. Sep 24, 2013 at 4:12 PM
    #49
    12PM4X4OR
    Fife
    none
    I've had good success with Griot's products in the past. I did a quick search on their site but I don't think I came across anything quite that permanent (years w/o fading). Any idea what this stuff is called?
  10. Sep 24, 2013 at 4:20 PM
    #50
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    I have read some stuff on 303 aerospace, anyone have any luck with it?
  11. Sep 24, 2013 at 5:02 PM
    #51
    hapajin
    hapajin Member
    Newbury Park, CA
    PreRunner SR5 2.7L 5-speed
    I have a 2003 Expedition with charcoal gray cladding and black side/rear steps. I had great results using Dupli-Color Flexible Bumper Coating spray cans that I found at my local Napa Auto parts store. I used the FB109 and FB105 part numbers, and got very good results.
    http://www.duplicolor.com/products/bumperCoating/?wwparam=1342038739
    The original panels were streaky, faded and looked like hell. Painting them completely transformed the look, plus they now need very little maintenance to keep them looking nice.
    Before spraying the bumper coating, I first used their "Prep Spray" (Grease and wax remover) and "Adhesion Promoter" (clear primer).
  12. Sep 24, 2013 at 5:28 PM
    #52
    texastaco11
    texastaco11 Well-Known Member
    Texas
    11 Prerunner TRD Sport 2wd
    I use it on all the black parts on the exterior, dash, windshield wipers and weatherstripping. Its awesome stuff. A little goes a long way. I also put it on my bakflip tonneau cover to keep all the rubber supple. My truck is only a 2011 but the blacks havent seemed fade in the tx sun. And its outside 24/7. You just have to wipe up any extra bc it can run a bit and you notice.
  13. Sep 24, 2013 at 5:30 PM
    #53
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I like
  14. Sep 24, 2013 at 5:32 PM
    #54
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I'm a big fan of the 303 protectant. Good UV protection with a matte finish, not shiny if that is what you want. Check over in the detailing section and you'll find a lot of info also.
  15. Sep 24, 2013 at 5:58 PM
    #55
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    thats what i like to hear, ordering some from Amazon. thanks
  16. Sep 24, 2013 at 7:36 PM
    #56
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    Wipe new...seriously. I put this on the 2nd week i had the truck and now a year later it still looks great. Make sure to clean the plastic with a good degreaser to get all the tire shine, shoe polish or whatever else youve tried off. The small bottle is enough to do the whole truck.
  17. Sep 24, 2013 at 8:44 PM
    #57
    Solo707
    Solo707 Well-Known Member
    NorCal
    2013 TRD Off-Road
    Plasti-Dipped Badges
    I can vouch for that. Looks like my door handles have been crying after a rainfall.
  18. Sep 24, 2013 at 8:52 PM
    #58
    fenderpicks
    fenderpicks Well-Known Member
    Edit
  19. Sep 24, 2013 at 8:58 PM
    #59
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
    Great thread. SUB!!!!
  20. Sep 24, 2013 at 9:00 PM
    #60
    Rich91710
    Rich
    Los Angeles
    08 Base
    $32 for a 30ml bottle?
    I think I'll use the heat gun.
