Black powdercoated fox 2.5 coils?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by that_06regularcab, Jul 17, 2025.
  1. Jul 17, 2025 at 1:42 PM
    that_06regularcab
    that_06regularcab [OP] 3rd gear wide open in a Toyota
    Southern Oregon
    Anybody ever powdercoat their Fox 2.5 coil springs to black rather than the factory silver?
  2. Jul 17, 2025 at 1:44 PM
    hoodwinked
    hoodwinked Well-Known Member
    How will people know they are Fox???
  3. Jul 17, 2025 at 1:47 PM
    that_06regularcab
    Southern Oregon
    lol I guess I’m not sure. Is that the cardinal sign they’re fox?
  4. Jul 17, 2025 at 1:49 PM
    hoodwinked
    I wonder if the powdercoat would affect heat dissipation negatively.
    JohnDoeFasho likes this.
  5. Jul 17, 2025 at 1:52 PM
    that_06regularcab
    Southern Oregon
    Im on the fence about it but I’m considering it because I’m working with a powdercoater on my suspension right now. I wouldn’t think it would affect them that way but I could be wrong
  6. Jul 17, 2025 at 2:00 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would think powder coat would wear off in the areas where it touches other metal at the two ends. When that happens I bet it would continue to disappear.
  7. Jul 17, 2025 at 4:07 PM
    JohnDoeFasho
    JohnDoeFasho Wading in the velvet sea
    2009 TRD Sport DCLB
    OTT Tune
    Powdercoating definitely doesn’t make things stronger to the best of my knowledge. Especially on something like springs… Too much heat.
    Seems like a risky, non-functional upgrade for something that is hyper-functional.
    Charlie Bravo likes this.
  8. Jul 17, 2025 at 4:12 PM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 Pro
    Not sure if this is trolling or you're retarded.
  9. Jul 17, 2025 at 4:16 PM
    JohnDoeFasho
    2009 TRD Sport DCLB
    OTT Tune
    Toilet baby
    hoodwinked and BabyBilly[QUOTED] like this.
  10. Jul 17, 2025 at 6:32 PM
    that_06regularcab
    Southern Oregon
    The goal wouldn't be to increase strength. It would be for aesthetic appearance because the frame and other suspension components are black. Not dead set on powdercoating though just curious if anyone else has done it since it's not uncommon for people to powdercoat custom lift kits.
  11. Jul 17, 2025 at 6:37 PM
    JohnDoeFasho
    2009 TRD Sport DCLB
    OTT Tune
    I was implying that it only makes it weaker. You are cooking your springs in an oven.
  12. Jul 17, 2025 at 6:44 PM
    that_06regularcab
    Southern Oregon
    I gotcha. I didn't know coil springs were known to break but Ive never really been in the suspension game so i wouldn't know. Depending on the material they're made of I wouldn't worry too much about 400° for 15 minutes. Hot dip galvanizing can take stuff up over 1000°F and with that there is the chance of warping but i wouldn't think it would compromise strength?
  13. Jul 17, 2025 at 11:48 PM
    hoodwinked
    Probably both, but never full retard. My statement stands though. Heat dissipation is likely not affected too much, but you are adding an additional layer of "stuff".....black in color.....over what is basically a giant aluminum heatsink. Will it matter? Probably not in any real world applications unless you beat the hell out of your suspension on 100+ degree days on the regular.
  14. Jul 18, 2025 at 6:09 AM
    BabyBilly
    Billy
    2020 Pro
    I'm still not sure if you're trolling or not. Why do you think springs, which are outside the shock body, are affecting heat dissipation of fluid contained within the shock body/external reservoir?
    To those concerned about weakening steel in a 400* powder coating oven...I don't even know where to begin.
  15. Jul 18, 2025 at 6:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    If that's your truck in the avatar, I'd make them either match the body paint or some accent color like red or lime.
    Black just blends away visually, and you need a pop of color to enhance the looks.
  16. Jul 18, 2025 at 12:35 PM
    hoodwinked
    I am clearly retarded and missed that he was asking specifically about the coil springs. I thought he was talking about powder coating the entire coilover, shock body and all....which is the component I was referring to when talking about heat dissipation.
    BabyBilly[QUOTED] likes this.
  17. Jul 18, 2025 at 7:01 PM
    JohnDoeFasho
    2009 TRD Sport DCLB
    OTT Tune
    Go outside nerd
  18. Jul 18, 2025 at 7:15 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Well, I’ve powder coated many items in the past. It is just paint at typically 5 microns thickness. If you are going to powder coat the shock bodies then you want them depressurized first. I wouldn’t stick a pressurized cylinder in my oven. If you do that then I would probably also have them rebuilt after having the seals and o-rings baked also. Powdercoat is just paint but once compromised it cannot be repaired. If you want to do something other than cerakote then just rattle can primer them and pick a paint of your choice. 2K epoxy are very resilient to exposure and abrasion. Powder coating a shock body seems a bit too much for me. Coils, sure do whatever you want but it is cheaper often to just buy new coils then have them stripped and powder coated.
  19. Jul 18, 2025 at 9:57 PM
    that_06regularcab
    Southern Oregon
    No definitely going that far I was just pondering powdering the coils:)
  20. Jul 18, 2025 at 10:04 PM
    that_06regularcab
    Southern Oregon
    I have some panels on my truck powdered black with flake and I’m doing that same color on my upper control arms and my sway bar. So I thought about doing the coils that color too, but I just powdercoated my frame black so I thought maybe just do black to match the frame. Idk im indecisive
