Black Rhino Armory wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by demogorgon217, Mar 27, 2021.
  1. Mar 28, 2021 at 10:36 AM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    You have a point, but being that you're using the taper of the lug nut, and locating it into the tape of the wheel, I feel confident. I have no reason to believe my cheapish wheels hub bore is any more accurate than the lug seats. That being said, next time they're off, I just might throw on some hub rings to see if it makes a difference. Although with my clapped out M/T's, I doubt I'd notice a difference.
  2. Mar 28, 2021 at 10:37 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    My only "reluctance" is that the only ones I had were bootleg looking plastic ones, and I was excited to get my cool, fancy new wheels on.
  3. Mar 28, 2021 at 10:40 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Like I said, not picking on anyone. Even discount tire direct was like, "You don't really need them but I guess we could send you them to you if you really want." Plastic ones are actually great (as long as quality plastic is used) because they won't corrode and get stuck on the hub.
    demogorgon217[OP] likes this.
  4. Mar 28, 2021 at 11:26 AM
    badger
    badger Well-Known Member
    07 SR5
    I wasn't challenging anything you said. There is no reason that conical lug nuts can't be just as accurate at locating the wheels. They definitely need to be tighten in a pattern. I go half tight, then full tight. The problems come from using washer type nuts with poorly fitting hubs. My comment was more of a general statement that aftermarket stuff requires some thinking because unlike OEM, it often does not get tested on particular vehicles. Some aftermarket stuff makes me wonder whether the designers ever actually installed it at all.
  5. Mar 28, 2021 at 12:17 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Thats a good point. As much water and mud as my truck sees, I guess the plastic ones would indeed be a better option for that reason.
    Agreed. Since OP doesn't seem to have much experience in this area, thats why I suggested buying from a dealer. Hopefully OP is able to gain some knowledge on the subject at the same time.
  6. Mar 28, 2021 at 6:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well, I'm glad everything is working out for you.
