Black Rhino Hard Alloys Abrams opinion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrWortWort, Mar 18, 2023.
  1. Mar 18, 2023 at 1:32 PM
    MrWortWort
    MrWortWort [OP] Well-Known Member
    2021 SR Access Cab Tacoma
    Any opinion on this rims?
    -18 offset rims
    Cast Aluminum
    32lb
  2. Mar 18, 2023 at 2:28 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Way to busy (gaudy) looking for my taste
    Koolbreeze7, BillyE, BigEasy and 2 others like this.
  3. Mar 18, 2023 at 2:30 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    post some pics mounted on on a truck.....then we will see
    Bcjammerx likes this.
  4. Mar 18, 2023 at 2:30 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I have the Stadiums because I also felt like there was alot going on there.
    RIX TUX likes this.
  5. Mar 18, 2023 at 2:33 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    It is a truck, sometimes goes offroad. They are gaudy, yes ... but off-road damage would be a crime even to those.
  6. Mar 18, 2023 at 2:49 PM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Would not want to try and keep those clean.
  7. Mar 18, 2023 at 3:01 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Get them if you like them.... Be prepared to spend time keeping them clean. You might need some dental tools to dig out the mall parking lot grit. you know...from all those little nooks and crannies.
    Really though... Get em' if u like em':yes:
    Road_Warrior, Chew and MadKatt like this.
  8. Mar 18, 2023 at 3:02 PM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Go for it...!
  9. Mar 18, 2023 at 3:27 PM
    Halloween
    Halloween Well-Known Member
    Toyotas a plenty
    They look good on taco’s.
    RIX TUX likes this.
  10. Mar 18, 2023 at 3:31 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Ouch
  11. Mar 18, 2023 at 3:46 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Too heavy for my taste. Combined with the tire to match...
    That being said, if you like them, got for it.
    BigEasy likes this.
  12. Mar 18, 2023 at 9:51 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    Ok I’ll be the one to say it. 32 lbs? Wow that’s a pig. I think stock OR rims are like 25 lbs.
    BigEasy and Chew like this.
  13. Mar 19, 2023 at 1:37 AM
    MrWortWort
    Stock rims are like 26-28lb
    Depends what style and year of rim
    TacoTrigger16[QUOTED] likes this.
  14. Mar 19, 2023 at 1:43 AM
    MrWortWort
    They're meant to be use for offroad
    Might as well use them
    The dents and scratches will give it style
    Just concern the big plastic caps cracking
    I don't understand why most offroad rims use plastic caps for covers/décor
  15. Mar 19, 2023 at 3:36 AM
    Unit59
    Unit59 Keystone State
    Craig
    East Central PA
    2023 Tacoma TRD OR
    -18 offset will poke out quite a bit, just be aware of that. I had that exact wheel and offset on a jeep wrangler, I didn't like how far they stuck out of the fenders.
  16. Mar 19, 2023 at 4:34 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Way too heavy for my liking. I try to stay in the low 20s.
    TacoTrigger16 likes this.
  17. Mar 19, 2023 at 4:43 AM
    burgershot
    burgershot Well-Known Member
    Too much weight and honestly fugly.
    Koolbreeze7 and na8rboy like this.
  18. Mar 19, 2023 at 4:56 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i agree they are a too busy especially for a stock truck. they might look OK depending on other mods to the truck. for example, if your truck has a lift, aftermarket bumper, nipple rings, rack, rtt, ditch lights, stickers/badges, etc., they might be OK and add to the look.
    i prefer a clean, less cluttered, look. besides the look, the biggest turn off is the weight as others posted.
    Koolbreeze7 likes this.
  19. Mar 19, 2023 at 5:07 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    hard, alloy, aluminum....overselling. forged is hard, alloy aluminum is not even it says "hard".
    that said I like some of their rims...not those but some.
    yeah hard to tell without on the truck views, should be able to find some websites selling wheels that have on vehicle views...or google. I've seen those on some sites, not my taste, but that's just me :)
  20. Mar 19, 2023 at 5:25 AM
    LkdTaco
    LkdTaco Well-Known Member
    2019 TRD PRO
    I can’t imagine the nightmare it would be trying to clean mud out of those things after a day trip to the national forest. I actually like the way they look, but because I am lazy, Hard pass for me.
