Black Rhino Sidewinder Help
Discussion in 'Wheels & Tires' started by SCHMEGGA, May 22, 2011.
  1. May 22, 2011 at 4:58 PM
    SCHMEGGA
    SCHMEGGA [OP] Token Gas Passer
    Shawn
    West Texas
    08 PreRunner TRD Off-Road
    I have a 2008 Tacoma DC TRD Offroad. Getting ready to pull trigger on Hankook Dynapro's 265/70/17 and the Black Rhino Sidewinder 17x9 wheel. Question is this: the sidewinder is a 12mm offset (positive) wheel. Will this be ok with my Tacoma. Thanks a bunch guys.
  2. May 22, 2011 at 5:01 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    IIRC it needs to be negative 12 offset
  3. May 22, 2011 at 5:13 PM
    SCHMEGGA
    Shawn
    West Texas
    I have seen on other sites that they are available in -12, but on discount tire, the 12mm is all they show available. I am having the hardest time finding the wheels I want for a stock lift with 265/70/17s.
  4. May 22, 2011 at 8:20 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The +12 will be fine I'd you never plan to step up above the 265s. That's 5.5" backspacing on a 9" wide wheel.
    However I would check the tire manufacturers site to make sure that size is approved for use on a 9" wide wheel. I'm thinking it will not be.
  5. May 23, 2011 at 8:03 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    The tire would look really stretched on a 9" rim, almost like a performance car tire. I wouldn't recommend it for off road driving.
