Black Rock 997 wheels, anyone have them?
Discussion in 'Wheels & Tires' started by HeadlampRevamp, Mar 22, 2010.
  1. Mar 22, 2010 at 2:40 PM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I really like the look of these wheels. They are also super cheap. Curious if anyone is running these or can offer a comment on their quality. Search didn't turn up much.
  2. Mar 22, 2010 at 5:15 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if you google "Type 8 wheels" you will likely find forum topics going back a good 10 years about these wheels not fitting on tacomas...
    the holes are dimple dies and they stick in about 1/32" and hit the brake vein on the front calipers...
    some have had luck grinding down the vein just enough to clear, while a number of folks miscalculated and ended up with a $350 repair...
    if you get them in a 5" backspace, then run some wheel spacers, you should be able to clear just fine...
    i have heard recently that there is a wheel maker who makes a soft 8 that will clear, and you may have luck finding them at Summit, but before you commit, you may want to find out what their return policy is before you drop the money and get stuck with the wheels...
  3. Mar 22, 2010 at 5:17 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i also saw a post recently on another toyota forum where someone bought these wheels, put them on his truck, and managed to drive about 4 feet when the wheels literally got stuck on the calipers...
    he said the truck would not move at all when he got on the throttle... i believe he may have had to replace the calipers and get some wheel spacers...
    needless to say he was a bit annoyed that he didn't hear about these wheels before purchasing...
  4. Mar 22, 2010 at 7:17 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    wow, def glad I asked, thanks man. I'll do some research on the type 8.
  5. Mar 22, 2010 at 7:20 PM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    do you know if the same is true for the 942 type D?
  6. Mar 22, 2010 at 8:50 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    D window steel wheels should be fine... tacos have been running those for years...
    i am on my 2nd set of D windows now...
    just make sure you get the right backspace for the tires you plan to run...
  7. Mar 23, 2010 at 9:49 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I plan on getting the 16x8 with 4.25"BS running 265/75. Will this pose any issues?
  8. Mar 23, 2010 at 3:02 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, you will be fine...
    if you later decide to run 285-75s, you will want 4" backspace...
  9. Mar 24, 2010 at 5:38 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    I found a set of Pacer 297B on craigslist for $250. Is that a good deal? Comes with front spacers, caps, and lug nuts. I'm assuming I shouldn't have any fitment issues because of the spacer, he said its .25"
  10. Mar 24, 2010 at 8:28 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    talk him down in price...
    if you can get the wheels for less than $50 each, used, it's a decent deal...
    you should be able to get them at Summit Racing for as low as $42 per wheel brand new...
    i tried a .25" plate spacer once, but I didn't like how short the stock studs ended up being, but if you keep them torqued, you should be good to go... you can always upgrade to longer wheel studs later...
    offer him $225 and see if he bites...
  11. Mar 25, 2010 at 8:42 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    He said he'd take $225. Good deal?
  12. Mar 25, 2010 at 9:59 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    go for it...
    would save you money on shipping...
    if you get there, and the wheels have any rash on them, drop the offer to 200 even...
