Black stuff coming out of oil filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldT, Dec 6, 2021.
  1. Dec 8, 2021 at 2:42 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Um, nooooo. You may clean out some sludge and build up grime, but you will pretty well wipe out the lubricating qualities of the oil. And I think you know what that leads to.
    Another online forum I participate in has a regular "contributor" who has the world biggest hack mechanic - who this guy idolizes. Anyway, the "contributor" posted up that he was having oil consumption problems, so he took it to his "mechanic." This guy flushes the engine (with 200+ thousand miles on it) with - wait for it - several gallons of Kerosene. Oh, it cleaned it out alright. Want to guess how the story ended?
  2. Dec 8, 2021 at 2:43 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The way I read it, these particles are coming out of the oil filter, they are not coming out of the oil pan. If this is correct, I believe the engine is neglected and your fresh oil changes are helping to clean out some buildup... sludge, carbon, whatever is built up in there. The oil filter is simply doing its job catching this stuff before it enters the oiling system. Short oil change intervals are not a bad idea for a while. An alternate approach would be running full oil change intervals but change the filter halfway through, and keep a close eye on the oil condition. Sounds like she's in good hands now, she'll be fine.
  3. Dec 8, 2021 at 2:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I hate it when the story teller leaves you hanging on the ending................
  4. Dec 8, 2021 at 6:08 PM
    Too Stroked
    Tom
    Boom.
  5. Dec 8, 2021 at 6:48 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    He barely drove it, heck you only put 4k miles in the last 14 months. Second oil change are you changing every 2k? Looks like some build up broke loose.
  6. Dec 8, 2021 at 7:00 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Frequent changes with quality oil - I like full synthetic Pennzoil - then run them 3-5k while monitoring the level. I had great success with this method with my old Subie and my Taco.
  7. Dec 8, 2021 at 7:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. You want to go slowly. When cleaning if a large chunk comes loose it can and will plug oil passages and the pump pickup strainer. Bye Bye engine.
    Too Stroked and Rick's 2012 like this.
  8. Dec 8, 2021 at 9:39 PM
    Waasheem
    Waasheem
    2007 xrunner
    I overheard someone telling a youngster how he puts a little atf in the crankcase to clean it. Youngster misunderstood, dumped the oil, refilled with atf. A few days later the engine was destroyed.
    I do it to my air compressor, put in about 3 tablespoons, it holds about 2 quarts of oil. Run it a couple minutes, then change the oil.
    Rambo MARINE Recon likes this.
  9. Dec 8, 2021 at 10:04 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    @OldT Do you have a 4.0? Was that bottle used to catch the oil from the filter drain "cup"? Could it be that crap was sitting in the drain "cup" and did not come out of the filter?
    winkel and Jimmyh like this.
  10. Dec 9, 2021 at 5:21 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    He needed to rebuild the sludge? Ohmfg. I can imagine what it sounded like and it wasn't pretty.
    And wow, I did not know that about seafoam thinning the oil out to the point of being useless. I usually throw a couple ounces in the oil with my last fill up of the gas tank before I change my oil.
  11. Dec 10, 2021 at 6:54 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Same here. Ive done the seafoam treatment plenty of times prior to an oil change in a bunch of different vehicles. I've never had an engine die on me yet. I personally wouldn't run seafoam 100% of the time in the oil, but I'm sure it's fine in the context here. (I do use it in every tank of gas in the chevy(sbc), but thats another story.)
  12. Dec 10, 2021 at 7:05 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Throw in a quart of Marvel Mystery oil, I believe it has a naptha base which makes sense it would help remove build up.
    I only use Toyota oil filters where possible, and run Napa (Valvoline) Full synthetic because it goes on sale for $4/qt or less
    wi_taco likes this.
  13. Dec 10, 2021 at 7:05 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Has anyone considered that is might just be some dirt and crap that got trapped inside the oil filter housing "drip ring" or whatever its called. OPs pictures show the dirt inside a cut up water bottle. Im guessing like most of us he used a water bottle to catch the oil that spills out as the filter is removed. I know mine is always filled with crap before I spin the filter off.
    winkel likes this.
  14. Dec 10, 2021 at 7:45 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Lol, this is my sentiment as well. I've run a few vehicles over 300,000 miles and have been using Fram for over 40 years. I guess I'm just a dumb ass. I do buy the expensive Fram filters though. I'm am a skeptic about all the Fram bashing when it's likely that all the "Fram failures" were due to something other than the piece of crap filter.
    SR-71A likes this.
  15. Dec 10, 2021 at 8:05 AM
    #35
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I've been adding about 5/6 ozs seafoam before an oil change to both vehicles and haven't seen any issues. I let them idle for about 10 minutes or drive around the block, a city block.
    I think it's like drinking, a little is good, but a lot is, well you know.
    Jimmyh likes this.
  16. Dec 10, 2021 at 7:55 PM
    #36
    dtaco10
    Dave
    Would the VVT screens need replacing?
  17. Dec 11, 2021 at 6:57 AM
    #37
    ARCHIVE
    Eric
    It very well could be the same scenario of "Ford trucks are crap", because they sell 800,000/year F-150s so they would have 8 times the issues if they achieve the same reliability as Tundras which only sold 100,000/year
    (The Tundra 5.7 is not as reliable as the 4.7 2UZ million mile Tundras, I see too many 2007/2008 Tundras for sale with blown up 5.7s and pretty low miles 100,000 to 150,000 miles)
    But I do put weight in dissecting new filters to see how they are made, and independent testing of flow and filtration
  18. Dec 13, 2021 at 2:26 PM
    #38
    DGXR
    Friend
    Sacramento, CA
    Maybe yes, if they are seriously gunked up or damaged. I would at least inspect them and clean out any debris with carb or brake cleaner. Also pull the solenoid and make sure it's not varnished up too bad and doesn't have any debris or carbon buildup. I used to inspect my VVT solenoid and oil screen (intake only) every 30k but they were always clean so I don't bother anymore, just keep on top of regular maintenance.
