Black Taco
Discussion in 'Wheels & Tires' started by E131198, Mar 24, 2008.
  1. Mar 24, 2008 at 10:38 PM
    E131198
    E131198 [OP] Member
    04 prerunner trd/sr5
    3" inch lift
    Hey everyone, I just found this forum. (glad I did). My question is I have a 2002 4x4 extended cab, trd, etc...taco. I'm going to lift my truck 3" revtek style. What are the best size wheels and tires? I was thinking of going 16x8, 265/75r16? Can I go wider, bigger, if so, will they rub? Just want to know if anyone out there has experienced a wider wheel and tire, and if they are happy? Any help would do:D
  2. Mar 25, 2008 at 2:51 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Hi. Welcome to Tacomaworld.
    It's early and I need coffee so instead of giving wrong information I'm going to suggest trying the search button in the blue bar near the top of the page. You'll find everything you need to make a great decision.... Or it'll make you think of even more questions. Either way it'll be fun. :D
  3. Mar 25, 2008 at 11:33 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Welcome to TW!
    Look around a bit and you'll find some good info. You can't go smaller that 16" wheels because of the size of the brake rotors. As far as width and rubbing, keep the backspacing around 4" or 4.5" (stock is 4.5") and you should be good. Worst case, just cut the fenders a bit if you rub with a set of wheels and tires that you really like! :cool:
  4. Apr 5, 2008 at 7:33 AM
    famousfernando
    famousfernando Well-Known Member
    oregon
    2007 tacoma trd package 6" fabtech l
    hey im runin 315/75R16 and it rubs alot i wouldn recomend it unless you want to start doin some grinding of metal
  5. Apr 5, 2008 at 11:30 AM
    Big Guns
    Big Guns Well-Known Member
    Temecula, CA
    07 PreRunner SR5 4.0L Indigo Blue
    Aero Turbine 2525 exhaust, Black Headlight Mod, DO Rock Sliders
    you can run up to a 285/75/16 with minimal rubbing on your 3" lift. Might have to trim a little but not too bad.
