Black trim around windows
Discussion in 'Detailing' started by Kotah, Jan 21, 2017.
  1. Jan 21, 2017 at 11:32 AM
    Kotah
    Kotah [OP] Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    How come the black trim around the outside side windows and back window get so spotty and shitty looking, you can clean and clean and black residue comes off but you still have the lighter blotches in it, any body come up with a way to restore this rubber trim. None of my non toyota vehicles does this.
    outlawtacoma likes this.
  2. Jan 21, 2017 at 11:41 AM
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    I have the same problem. Curious to see what people say
  3. Jan 21, 2017 at 12:31 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Wolfgang Exterior Trim Sealant from Autogeek is the best I've found. Wipe on, wipe off. Repeat in 24 hours. And then you should be good for a few months. It's one of the best trim sealants out there. The window trim you speak of is finicky. It doesn't absorb product like other trim. But a double or triple application with some cure time in between seems to be the best solution.
    Expensive but a little goes a long way (also available on Amazon). The trim needs to be cleaned very well with an all purpose cleaner before application of the Sealant.
    shakerhood likes this.
  4. Jan 22, 2017 at 5:11 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You'll need a rubber conditioner and sealer. Something to prevent it from cracking due to UV exposure.
    But you cannot really restore damaged trim. You have to do your best to prevent the damage to begin with.
  5. Jan 22, 2017 at 7:22 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    It seems to me this from dried up water after it rains. Doesn't appear the water drains or runs off very well from the rubber trim. I had to scrub the shit out of mine and use a dedicated rubber cleaner to get them back in shape. I was able to get rid of the blotches. Since my truck has some age on it, I coated the trim with a ceramic coating. Will see if it works or if I am just pissing in the wind.
  6. Jan 22, 2017 at 9:58 AM
    NMTrailRider
    New Mexico
    Actually there are some good trim restore products out there. These are the two I see most mentioned. There's also this. Generally applied first to restore color, then its sealed with something like dLux.
  7. Jan 22, 2017 at 2:03 PM
    PackCon
    Connor
    Have you used this??
    The powdercoat is failing on my power running boards. I'm looking for something to cover it up.
  8. Jan 22, 2017 at 3:15 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had just bought some of this stuff a few weeks ago.
  9. Jan 22, 2017 at 3:49 PM
    NMTrailRider
    New Mexico
    Good stuff, eh?
  10. Jan 22, 2017 at 3:57 PM
    NMTrailRider
    New Mexico
    It's for black plastic and vinyl. I don't think it would do much for failing powdercoat. But I've not used it myself. I've just read a lot about it over on AG. Most recommend applying then sealing it with something else.
    There are a ton of threads about it over on AG. Here's a sampling:
    http://www.autogeekonline.net/forum...h-solution-dull-faded-plastic-vinyl-trim.html
    http://www.autogeekonline.net/forum/auto-detailing-101/102477-dlux-over-solution-finish.html
    http://www.autogeekonline.net/forum/show-n-shine/100022-solution-finish-rescue.html
    http://www.autogeekonline.net/forum/product-reviews/80643-solution-finish.html
    Another note about the previously mentioned Wolfgang Exterior Trim sealant-- just a few drops will be enough for a windshield cowel, for example. And 2 or 3 drops for trim on one window. It's oily and spreads a long way. So, when you see the price tag on 4oz., that's why. That bottle will go a long way.
  11. Jan 22, 2017 at 4:36 PM
    shakerhood
    Southern Ohio
    I am not sure yet, I bought it to put on the new truck when I get it.
  12. Feb 9, 2017 at 9:47 AM
    WolfWengler
    WolfWengler smart old fucker
    Wolf
    Colorado
    2017 Access Cab V6 auto
  13. Feb 9, 2017 at 11:39 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    You think GoJo would take paint sealant off black plastic? I got some on the black bed rail caps last summer and the darn stuff never started looking white till it got cold. I tried a pink eraser I bought from Walmart on a little spot this morning but it never took it off. It was 17 degrees out also so I don't know if that had anything to do with it or not.
  14. Feb 9, 2017 at 11:44 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    WIll this work also on plastic if I got wax on it?
  15. Feb 9, 2017 at 6:29 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    2013 X-Runner Supercharged/2001 4Runner sport
    Urd intake Urd stealth pulley Djm 3/4 DTLT headers Urd o2 sim Urd trac bar Afe 3" cat back Xii performance stock coils
    Degreaser mixed w water and a brush.keep it off paint
  16. Feb 9, 2017 at 7:14 PM
    CusterFan
    It will be impossible to keep it off the paint. Probably just going to have to live with it.
  17. Feb 9, 2017 at 7:16 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    Won't ruin paint it will just strip any wax or sealant on paint
    CusterFan likes this.
  18. Feb 9, 2017 at 9:12 PM
    NMTrailRider
    New Mexico
    McKee's Wax Remover For Plastic is a decent product. Spray, dwell, spray, lightly scrub with a soft bristled brush (some trim/plastics can handle some abuse).
    https://www.amazon.com/McKees-37-MK37-530-Remover-Plastic/dp/B01LF3FU9G
    You can also just use APC. I'd wait until right before you apply your next coat of sealer. Then get it done all in one shot. I don't think there's any product that will leave a wax or sealer untouched (after all, that's what we are asking the product to do). And it's a lot thinner on paint than it is gunked up and white on the trim.
    (I know you prob know this already, but I put it here for others)
  19. Feb 9, 2017 at 9:19 PM
    NMTrailRider
    New Mexico
    I love that stuff. Used to use it when I worked on a drilling rig years ago drilling geological exploration holes. I can still smell it! But I've only used it on my hands!
  20. Feb 10, 2017 at 7:13 AM
    CusterFan
