Black Wheel Suggestions
Discussion in 'Wheels & Tires' started by Faoloan, Feb 26, 2019.
  1. Mar 2, 2019 at 2:44 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    T
    That sucks
    dmo1028[QUOTED] likes this.
  2. Mar 4, 2019 at 1:49 PM
    dmo1028
    dmo1028 Well-Known Member
    Dave
    North Carolina
    2019 DCSB AT TRD Sport 4x4 Quicksand
    265/70/17 Wildpeak’s on TRD Pro SEMA’s
    Just as a follow up, my last wheel was delivered today so I was able to go and get them installed. Very happy with the look!
    hkdtaco likes this.
  3. Mar 4, 2019 at 6:02 PM
    Cpprunner17
    Cpprunner17 Member
    Albert
    2016 Tacoma SR5 2WD silver
    So clean!
    Armed in Utah[QUOTED] likes this.
  4. Mar 4, 2019 at 6:08 PM
    Cpprunner17
    Cpprunner17 Member
    Albert
    I'm in the same boat as you! I was looking at 398 Manx vision wheels as well. With the help of Arizona_Tacoma, I discovered I'd need wheel hub centric rings if I were to buy visions. I guess the center bore on a stock tacoma measures 106.1mm but the vision rims only come in a 110mm bore width. The rings will fill in that void and avoid any possible vibrations.
  5. Mar 4, 2019 at 6:54 PM
    Dawgs1125mbsr
    Dawgs1125mbsr Well-Known Member
  6. Mar 4, 2019 at 6:55 PM
    Dawgs1125mbsr
    What do those TRD Pros run? Where did u get them?
  7. Mar 4, 2019 at 7:02 PM
    dmo1028
    Dave
    North Carolina
    I got them from bam wholesale parts.com for $723 shipped.
  8. Mar 6, 2019 at 4:29 PM
    G.T.
    G.T.
    CONUS
    When searching for wheels and you find something in your budget that you like check to see if your factory TPMS sensors will fit - ours are attached to the valve stem - so you don’t have to buy new and get them programmed saving you some loot.
    Running black wheels myself.
    Photo by @Taco16Jessy
    Taco16Jessy likes this.
  9. Mar 12, 2019 at 7:28 PM
    Faoloan
    Faoloan [OP] Member
    Good information, thanks
    G.T.[QUOTED] likes this.
  10. Mar 12, 2019 at 7:28 PM
    Faoloan
    Faoloan [OP] Member
    Great to know, I'll keep this information handy in case I go with the Manx visions
