Black Wheel Vinyl to cover chrome TRD Off Road 16’ - 19’
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by Pikestaco, Nov 29, 2017.
  1. Nov 30, 2017 at 6:47 PM
    #41
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Both look pretty close, would probably want to try both to see which matches best on the wheels. I actually like these wheels’ painted color a lot on my SSM truck, but the silver on the wheels would look better matched to the rest of the paint IMO
    shakerhood likes this.
  2. Nov 30, 2017 at 6:49 PM
    #42
    Pikestaco
    Pikestaco [OP] Newbie
    Los Angeles
    2017 Quicksand 4x4 TRD Sport DCLB
    need to learn more about this stuff
    i agree. both look good. i'll see if my sister can find those for cheaper somewhere. everywhere i looked you had to buy a TON of it and it was $100+ a roll. Would have to have a bunch of "for sure buying" types before pulled the trigger on something like that
  3. Nov 30, 2017 at 7:03 PM
    #43
    bshammer0
    Brandon
    Nashville, TN
    Surely you could get them to send samples so you could chose the right color (and be able to get a good pic even on a small section) and your “for sure” crowd would likely grow quickly
  4. Nov 30, 2017 at 8:25 PM
    #44
    Bstap04
    Bstap04 Member
    Yea, I'd be in for color matched for sure
  5. Dec 1, 2017 at 5:17 AM
    #45
    Miller1103
    Miller1103 Well-Known Member
    2017 trd or dc quickaand
    Thank you and your sister for doing this. Saved me a lot of money not buying new rims :)
    thomas3ford likes this.
  6. Dec 2, 2017 at 10:26 AM
    #46
    Pikestaco
    Los Angeles
    As you guys receive them if you can take pics and or even video that would be awesome!!
  7. Dec 2, 2017 at 6:35 PM
    #47
    Miller1103
    Will do. Can't wait
  8. Dec 2, 2017 at 10:32 PM
    #48
    MN_Tacoma
    MN_Tacoma Active Member
    2017 TRD OR DCLB Quicksand
    Gator Tonneau, TRD Pro Grille, Weathertech floorliners, Weathertech hood protector, AVS vent visors, Magnum RT Nerf Bars, LED dome/plate lights, Blackout overlays, Tailgate Inlay, Glovebox Inlay, Carista (delete seatbelt beep)
    Absolutely, no problem but I don't have long enough access to a heated shop until Mid January. It's too COLD in the frozen north to apply outside this time of year and expect good results. :mad:
  9. Dec 5, 2017 at 6:43 AM
    #49
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    @Pikestaco have orders been shipping? I have not received any notification and I ordered last week.
  10. Dec 5, 2017 at 7:03 AM
    #50
    Pikestaco
    Los Angeles
    All orders shipper out yesterday. You will receive them in the next couple days.
    The_DarkTaco likes this.
  11. Dec 5, 2017 at 8:27 AM
    #51
    Shellshock
    Iowa
    I was gonna try to do an install video but the weather sucks here so it’ll be a while before I can even attempt that. Since orders are shipping now, just wanted to do a quick write up on what I did for my installation.
    Be sure to set aside plenty of time, it’s a lot of pieces to apply and to do it right will take a while.
    You’ll want to apply these vinyls to a dry clean wheel. I’ve done other vinyls with a wet application but that will not work for this. I tried and with the tiny surface area and shape it makes it impossible to keep the vinyl placed and get the fluid out.
    Here we go -
    1) Clean the wheels. I used a spray bottle filled with water. Spray it on. Wipe it off. I live on a gravel road so this is a good first cleaning to get the major dirt off.
    2) Clean the surface with alcohol. I’ve always done this when applying vinyls. It does a good job of one last cleaning and dries quickly.
    3) Double check the wheel and make sure it is clean and dry.
    4) Start applying vinyls. Peel the entire vinyl from sheet. I would align the inner most part first - the bottom of the U shaped piece. Lightly stick this to the wheel and check alignment. Assuming you’ve got the wheels thoroughly cleaned and haven’t fully pressed on the vinyl, you can pull it up and adjust as needed. I’d recommend starting with the top of a wheel first. Then going around from there. You could also take the wheel off for application but I did it still on the truck without issue. The ones on the sides can be somewhat tricky but it’s not that bad. Take your time and adjust as necessary.
    Once you’ve got the inner most part lined up, start lining up one of the sides. These were usually the trickiest part because of you didn’t have the bottom part aligned these could end up being way off. They will stretch a little bit but if you are off by too much I’d peel the whole thing off and start again. Some of mine I peeled off 3-4 times and they are still holding fine once I finished.
    The very last part is the little lip at the top. This is where you’ll take advantage of the stretch in the vinyl. I would take and stretch it a bit to make sure you fill the gap between the two pieces. I overlapped it with the next piece I’d place so there was no gap and it would appear to be one large piece.
    Once you are satisfied with the alignment go over the entire vinyl and press to onto the wheel. I used a little plastic scraper but you can also use a credit card or some other plastic card. Work out all the air bubbles. You can typically just push them to an edge and get them worked out. If you’ve got one that you are having trouble getting out you can use a pin to poke a hole in the center of it to let the air out. Once you’ve forced the air out you’ll never notice the hole.
    Repeat this for the next 5 and you’ll have a wheel completed.
    That should pretty much cover it. If anyone has questions let me know.
    Doing the first wheel was the hardest. After that you get a feel for it and the next wheels go much faster.
  12. Dec 6, 2017 at 2:39 PM
    #52
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    So far only one side done. But for first time ever dabbling in vinyl, I feel I did pretty well.
  13. Dec 6, 2017 at 3:05 PM
    #53
    The_DarkTaco
    The_DarkTaco Member
    Southern California
    2017 Black Tacoma TRD Offroad 4x4 DCSB
    Looks solid! Dumb question did you pop of the yota logo under the trd decal, place it over it, or replace the center cap.
  14. Dec 6, 2017 at 3:11 PM
    #54
    Pikestaco
    Los Angeles
    DANG. makes the OR wheel look super good. if they just wouldn't have done the chrome, it could have been a GREAT wheel OEM. Great job applying them!
  15. Dec 6, 2017 at 3:40 PM
    #55
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    looks GREAT!Where did you get the TRD emblems?
  16. Dec 6, 2017 at 5:06 PM
    #56
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    I popped out the logo from the rear. I ordered a set of 60mm stickers from eBay for $15. They look awesome and make the vinyl adding even better.
    Thank you! I've never done anything of the sort and had some issues with bubbles at first and then some of the small skinny ends don't wanna stick to well but so far they look great. They definitely should have kept the wheel all the same color that would make these awesome.
    I got them off eBay. https://www.ebay.com/itm/152743264331
    #56
    RaiderJ likes this.
  17. Dec 6, 2017 at 5:20 PM
    #57
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Looks awesome man...!!
    Now you just need Black Chromed nuts... hehe
    Sorry, didn't mean to "anti-chrome" or anything....!:rofl:
    #57
  18. Dec 7, 2017 at 6:08 AM
    #58
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    I’m ready to order one! I’m going to use Venmo but a little hesitant with so many names with Pike on Venmo . I just want to confirm there’s no picture attached to the account? I think it would be a good idea to attach a picture of a Tacoma or something similar so we know who we are paying.
  19. Dec 7, 2017 at 6:25 AM
    #59
    bshammer0
    Brandon
    Nashville, TN
    Looking good even w/ the black. Next gen on these would be... ONE piece per wheel. though my guess is that would require a huge printer / cutter and require outside work. I'd just love them to not be discernible as individual stickers by being a single sheet. Or could be something similar to the tacoma tailgate letters I got where it was all one sheet, lined up the "O" and everything else was perfectly fit in place?
  20. Dec 7, 2017 at 6:54 AM
    #60
    Pikestaco
    Los Angeles
    You are right. There isn’t picture. I’ll mention to her putting a pic of a wheel or Tacoma. Good suggestion.
