BLACKFRIDAY IN OCTOBER
Discussion in 'Deals & Coupons' started by JLee, Oct 9, 2020.
  1. Oct 9, 2020 at 2:41 PM
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  2. Oct 9, 2020 at 5:19 PM
    Jessee26
    Jessee26 Well-Known Member
    Jessee
    Virginia
    16' TRD Sport Red
    Is there a code I use or already priced with discount?
  3. Oct 9, 2020 at 7:30 PM
    JLee
    Jerry
    Benicia, CA
    No codes necessary all discounts will be applied in the cart.
  4. Oct 10, 2020 at 12:25 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Just ordered mid and t case
    Grossomotto, pdaddy and JLee[OP] like this.
  5. Oct 11, 2020 at 11:38 AM
    Emanresu
    Emanresu Well-Known Member
    @JLee With the 3rd Gen High Clearance Rear Dual Swing Out Bumper... what size tires can be mounted with the dual tire carriers?
  6. Oct 11, 2020 at 11:39 AM
    Emanresu
    Also, you have a min and max weight listed depending on orientation. Im guessing this would be the max(400lbs)?
  7. Oct 12, 2020 at 6:01 AM
    JLee
    Jerry
    Benicia, CA
    We currently have a customer running a 37x12.50" with no issues.
    That's shipping weight we still don't have a full weight with all options added, as the small ones are still being designed.
  8. Oct 12, 2020 at 6:27 AM
    Emanresu
    Hes running two 37's side by side? Im looking to fit two 35's. Thanks for the info!
  9. Oct 12, 2020 at 6:31 AM
    JLee
    Jerry
    Benicia, CA
    No not I miss read that. Not a single person is running two tires as of right now. And 33's would be the biggest without blocking the tail lights.
  10. Oct 12, 2020 at 6:33 AM
    Emanresu
    Gotcha, thanks
  11. Oct 16, 2020 at 5:08 PM
    Dan4589
    Dan4589 Well-Known Member
    Daniel
    2016 Tacoma sr5
    Can I get a website???
  12. Oct 16, 2020 at 5:13 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yeah click on the big Halloween pic in the first post
    Dan4589 likes this.
  13. Oct 29, 2020 at 12:41 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    @JLee just got your beefy t case skid. Waiting for UPS to send the mid now!
    The t case did not come with mounting hardware. What will I be needing to get this bad boy mounted ? Aside from the mid skid (assuming needing that hardware too)
  14. Oct 29, 2020 at 12:55 PM
    JLee
    Jerry
    Benicia, CA
    All skids come with hardware if you are still waiting on packages the bolts are in the other boxes.
    Dirk Diggler[QUOTED] likes this.
  15. Oct 29, 2020 at 12:59 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Gotcha thanks for the quick reply! Incredibly excited to get these monsters on and see where it can get them used at windrock
  16. Oct 31, 2020 at 8:35 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
