Blackhorn Wheel correct fit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by petcotaco, Mar 1, 2021.
  1. Mar 1, 2021 at 2:25 PM
    petcotaco
    petcotaco [OP] Member
    Dan
    2005 Tacoma TRD sport short bed
    K&N air filter, are bed cover
    I'm looking at new Canadian wheel company "Blackhorn wheels" they have a BH02 wheel in
    17x9.0 +12 6x139.7 106.1 question will this size fit my 2005 Tacoma 6 lug not lifted?
    If so what is largest Faulken wildpeaks I can run with on those wheels?
    Thank you very much
    Dan
  2. Mar 1, 2021 at 3:33 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I think most here run a 0 offset with a 9" wide wheel to get a little poke out. I think it will fit, however if you ran larger then a 33" tire or wider then a 12" tire i believe the tire will rub the upper control arm.
    Im definetly no wheel fitment expert though. Hopefully that helps!
    petcotaco[QUOTED][OP] likes this.
  3. Mar 1, 2021 at 3:43 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Largest tire size on stock suspension. 265/70/17 but I would go with a 17x8 instead of 17x9 wheel for a tighter tire bead. +12 offset is close to factory.
  4. Mar 1, 2021 at 4:51 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    That’s a 5.5” backspace. That’s pretty much the limit for backspace. If you’re planning staying stock. Go 17x8 0 offset. 265/70/17 like Watta mentioned. It’s a good happy medium.
    petcotaco[OP] likes this.
  5. Mar 2, 2021 at 7:11 AM
    petcotaco
    Dan
    So in your opinion would I be safe ordering these "17x9.0 +12 6x139.7 106.1" even though 9" wide wheels as this is only size they have for my 2005 tacoma no lift? and the 70 instead of 65 tires or stay with 65 due to 19 wide?
    Thanks i appreciate your knowledge...
    Dan
  6. Mar 2, 2021 at 10:43 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    265/70/17 is the same width (approx 10.5" wide) as a 265/65/17. 265 is the width value but I would go with the 70 ratio tire which is 1" taller than a 65 ratio tire. 265/65/17 will be a tad small IMO.. If you don't plan on offroading in low psi situations, then the setup would be fine with a 9" wide wheel. If you do experience minor rubbing with a 9" wide wheel, it can be easily corrected with a small spacer. Not my preference for offset or width but if you are really set on this particular wheel style, then you can make it work.
  7. Mar 3, 2021 at 9:34 AM
    petcotaco
    Dan
    Thank you very much !! going with the Blackhorn BH02"s
