Blacktacoma23's Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Blacktacoma23, Mar 15, 2011.
  1. May 12, 2015 at 6:37 PM
    #881
    Blacktacoma23
    Blacktacoma23 [OP] If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  2. May 16, 2015 at 11:58 AM
    #882
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    :popcorn:I think those Grapplers you had were for some other dudes truck. :luvya:
  3. May 16, 2015 at 9:36 PM
    #883
    Blacktacoma23
    2011 Mall Crawler
    Oh you got me...
    For a friends jeep
  4. May 18, 2015 at 6:22 AM
    #884
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Well damn....
  5. May 18, 2015 at 6:35 AM
    #885
    Blacktacoma23
    2011 Mall Crawler
    I'm jk!
    Tars are in my shed waiting to be put on
  6. May 18, 2015 at 7:24 AM
    #886
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    How much longer till truck is back from shop?
  7. May 18, 2015 at 8:17 AM
    #887
    Blacktacoma23
    2011 Mall Crawler
    Not sure, but I know she is in good hands
  8. May 18, 2015 at 8:27 AM
    #888
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  9. May 18, 2015 at 9:11 AM
    #889
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    That's good
  10. May 18, 2015 at 2:19 PM
    #890
    Blacktacoma23
    2011 Mall Crawler
    Not a bad Monday !
    XPOTRON and NCtaco914 like this.
  11. May 18, 2015 at 2:28 PM
    #891
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Just a heads up buddy, none of the LCA's are designed around aftermarket spindles so you will have to do two easy things :
    1. trim your steering stops a bit on your spindles. Super easy to do, just keep trimming until your steering radius feels the same. That gusset from the cup to the arm is actually a landing pad for your steer stops and they make it out of stainless steel so when your stop hits it a and rubs the paint off of it it does not rust and stays shiny.
    2. Where your ball joint adapter bolts onto the bottom of your spindle you will most likely need to put 1 washer between the adaptor and the spindle which will space it down a hair and create clearance for the top of the uniball to clear the spindle at droop. Hope that makes sense if not I can snap a couple pics for you later.
    P.S. I will stop by crown for you this week, you should be able to figure out the install from that one pic I posted of mine.
  12. May 18, 2015 at 2:30 PM
    #892
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Edit - that info is based on a PC spindle so your BDS may or may not have the same issues ?
  13. May 18, 2015 at 2:41 PM
    #893
    Blacktacoma23
    2011 Mall Crawler
    Thx for the info and thanks for going to Crown!
    I called but no luck
  14. May 18, 2015 at 7:40 PM
    #894
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Dirt king lowers. This is going to be interesting. All you need now is glass. ;)
  15. May 18, 2015 at 7:54 PM
    #895
    Blacktacoma23
    2011 Mall Crawler
    Negative!
  16. May 19, 2015 at 1:46 AM
    #896
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    I miss the glass!!!:bananadance:
  17. May 19, 2015 at 7:32 AM
    #897
    Blacktacoma23
    2011 Mall Crawler
    How was the fitment of the DK lowers and your spindles?
  18. May 19, 2015 at 7:34 AM
    #898
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    So far everything looks perfect, need to do a test run still and see how it does tho
  19. May 19, 2015 at 6:50 PM
    #899
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Hey Matt, I'm going to stop by Crown for you tomorrow. Do your BDS spindles have a hole all they way through where the sway bar would mount ? That Hole is what I used to secure an L bracket to hold the brake hose ( see photo ) The fitting for the L bracket is installed over the hose before the fittings are put on the hose. The hose " floats" through the L bracket so if your mounting location is not identical it does not matter. If you can use that same mountiing location he can build the kit exactly the same as mine hardware included.
  20. May 20, 2015 at 12:53 AM
    #900
    Blacktacoma23
    2011 Mall Crawler
    Yea pretty positive I have a hole there also!
    Thanks man
