Blank switches.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LoganNolag, Jun 26, 2018.
  1. Jun 26, 2018 at 12:15 PM
    LoganNolag
    LoganNolag [OP] Well-Known Member
    Does anybody know if there is a reason why Toyota uses a different switch location for ECT power and the Clutch Start Cancel buttons?
    It seems strange that they don’t use the same switch location for those 2 buttons since the Clutch Start Cancel button is only installed in the manual transmission trucks and the ECT power button is only installed in the automatic trucks.
    Because they use a different switch location for the buttons fully loaded Tacomas always have a blank switch. All automatics have a blank switch to the left of the steering wheel where the Clutch Start Cancel button is on the manual trucks and all manual trucks have a blank switch in the center console where the ECT power button is on the automatic trucks.
    If I were designing the interior I would have used the same location for both switches that way a fully loaded truck wouldn’t have any blank switches. Just seems like a strange oversight especially considering that both functions are transmission related.
    BSFord likes this.
  2. Jun 26, 2018 at 12:33 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Blank switch locations are great. Just look at mesojdm's custom switch panel thread for folks who want moar locations. I have a seven switch panel that I need to get installed and only have plans for five at the moment.
    This is not even mentioning the truck industry trend of putting in factory aux switches like on the Jeep JL and the Ford pickups.
  3. Jun 26, 2018 at 12:42 PM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    And why are the side windows, sunroof, and rear sliding window switches all over the place?
  4. Jun 26, 2018 at 1:24 PM
    LoganNolag
    Seriously it seems like a problem with all car companies. I have never been able to figure out how they decide on the switch locations.
  5. Jul 4, 2018 at 8:19 PM
    LoganNolag
    So it looks like I answered my own question. It seems like the reason there is always a blank button is for the glass break sensor. Here is a photo of one with the sensor installed: https://carpictureupdate.com/wp-con...rive-of-toyota-tundra-manual-transmission.jpg and here is the part: https://parts.toyota.com/p/Toyota_2018_Tacoma/Security-System/69524469/PT39835160.html
    In this photo of the part on Amazon you can see the indicator that goes into the blank switch spot https://www.amazon.com/Toyota-PT398-35160-Intrusion-Protection-Security/dp/B014JF36QQ
    Now it makes sense why there is always a blank button but I still find it strange that they don't put the ECT power switch and the Clutch Start Cancel switches in the same place.
  6. Jul 4, 2018 at 8:31 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    The youngest, least experienced engineer gets the job of switch layout. :annoyed: Either that or it’s the oldest one with a don’t give a crap attitude :thumbsup:
  7. Jul 4, 2018 at 8:32 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    What I need help with is how to remove the switch panel under the climate controls to add a couple of switches and the alarm sensor.
  8. Jul 23, 2019 at 9:22 AM
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    If you still are looking at how to remove the panel under the HVAC controls I can help. It's kinda in depth and requires a few others to be removed or dropped down first. I can post pics later if you want. I'm getting ready to tear my interior apart for the millionth time.
