Blasted electric connector
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Big Mort, Oct 15, 2023.
  1. Oct 15, 2023 at 11:45 AM
    Big Mort
    Big Mort [OP] Member
    Craig
    Tacoma long bed
    4" lift, larger rims and tires
    I am changing spark plugs on my 2019 Tacoma, 6 cyl. I have the passenger side done. I am stopped by one lousy electric connector over the middle plug on the driver side. I have half of the fixture disconnected but the second half is sitting on some kind of post mounted to the engine and I can not see how to release it. I have tried everything I can think of for 4 hours. Anyone know how this thing releases. HELP!!!!
  2. Oct 15, 2023 at 11:55 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Oct 15, 2023 at 12:14 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    A couple of suggestions:
    1. Find a similar connector in a more accessible location and practice on that.
    2. Sometimes even when you press the release tab, the lock does not release. See if you can get a pick tool under the lock to hold it open while you separate the connector.
    3. Sometimes the connector doesn't seem to want to come apart even when you're sure the lock is released. Try to use a mini pry bar to gently pry apart the two halves of the connector.
  4. Oct 15, 2023 at 12:39 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Pics?
  5. Oct 15, 2023 at 1:42 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I just changed the plugs on my 2018 about 5K miles ago. If it is the middle plastic post, I am thinking of it pushes in and then pulls up to release. Then you can get to the driver's side plugs. Good luck?!
    Steves104x4 likes this.
