Blazer Fogs in Factory Fog Housing
Discussion in 'Lighting' started by Yota Toy, Aug 13, 2011.
  1. Oct 7, 2011 at 5:30 AM
    Yota Toy
    Yota Toy [OP] Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    I would simply use the factory high-beam circuit to activate the solenoid. The challenge for me is finding bi-xenon lights that are completely sealed.
  2. Oct 7, 2011 at 10:01 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    NE Ohio
    2021 SR5
    What's the "return wire down" mod? I just ordered these from TRS for my motorcycle.
  3. Oct 7, 2011 at 10:13 AM
    Yota Toy
    Simply clocking the bulb 180 degrees, which puts the return wire down. In the return-wire-up position the wire itself blocks some of the light. It really did make a noticeable difference. To clock it 180 you need to remove a tiny little bump on the bulb itself, which is the "stop" normally. You might think this would leave the bulb loose or allow it to turn on its own but the gasket is plenty grippy to keep it from turning. There is a thread here somewhere that has some before and after pics, and a quick writeup.
  4. Oct 25, 2011 at 6:42 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Did you use the complete kit?? Or what piece/parts are required to make it work?? And where did you find the heat sinks?
  5. Oct 25, 2011 at 6:44 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  6. Oct 25, 2011 at 6:51 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    s2k baby you already have the LS460 don't cheap out now lol
    i'm going to have bjorn do a set of those for me in the fog lights i have in the arb they are a thick glass lens so it's gonna be a nice match a set of those in 55 watt 3000k will cut through any weather brother.
    i had thought about doing the mini H1 in there but i'm not sure i want a true quad set up i think i just want really bad ass fog lights those s2k's are like almost 10 lanes wide lol and intense as hell it's gonna be epic.
  7. Oct 25, 2011 at 8:23 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    Not trying to take over for OP but this is what i gathered....But i would like to make sure with OP as well :)
    TRS has the blzer kit. then for the heatsinks i googled and found this:
    http://effluxrc.com/28mm-Heat-Sink-axial-finned-2836HS.htm
  8. Oct 25, 2011 at 8:24 AM
    AsianAnts
    AnT
    dude dont say that... my ass is charrd because my wallet is on fire.
  9. Oct 25, 2011 at 8:55 AM
    AsianAnts
    AnT
    Although the link below supplies the heatsinks, the shipping is just almost as much!!!!
    I found a different site with a bit different style heatsink but the measurements the same. And shipping is 3 bucks! I'd get this instead. Scroll all almost all the way to the bottom and look for:
    GWS Heat Sink for BL28XX Inrunners
    GWS Heat Sink for 28mm Inrunner type motors
    SKU Number:GWACS021
    Price: $3.75
    http://www.radicalrc.com/category/Motor-Mounts-&-Heat-Sinks-98
  10. Oct 25, 2011 at 6:36 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    I think I'm going to do projector fogs after I do my headlights...I was looking at my cousins Nissan 240sx n he has projector fogs...so I think ima pull the trigger on them :D
  11. Oct 26, 2011 at 5:38 AM
    Yota Toy
  12. Nov 4, 2011 at 8:26 PM
    AsianAnts
    AnT
    Just an FYI for those who want to save a few bucks, the link I provided for the heat sink works perfect. Also utilizes a screw/nut to fasten it onto the blazers. If you want, you can dab a bit of JB Weld. I think the lesser amount of JB Weld used the better the heat sink will serve its purpose. JB Weld not needed of course since the screw/nut method works just fine without.
    SKU Number:GWACS021
    Price: $3.75
    Click Her for the HeatSink
  13. Nov 7, 2011 at 6:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :eek:
    When did you get those?!?!
  14. Nov 8, 2011 at 11:42 AM
    Pugga
    Massachusetts
    Getting ready to pull the trigger on these and had an epiphany :eek: You two who have already done this mod, I wanted to get your input to see if this would work... Instead of drilling from the back of the fog light housing, I want to cut off the front of the housing and use a shroud to fill the gap between the blazer set up and the stock fog light housing. I would not be putting the clear lens back over the front of the blazer so it'd end up looking something like this:
    What do you think? Opinions? Comments? Observations? I think it'll look pretty slick if I can make it fit. I put in an e-mail to TRS to get some sizes on things. I'll let you know.
  15. Nov 8, 2011 at 12:35 PM
    #35
    Yota Toy
    Since the Blazer fogs are completely sealed I think you could pull that off fairly easily. I did mine in the factory housing because I wanted them to look as stock as possible while still having increased performance. Plus, keeping the factory housing allows use of the factory adjuster. If you do go with a shroud like above, please post pics!
  16. Nov 8, 2011 at 12:37 PM
    #36
    Pugga
    Massachusetts
    I would still stick the back of the blazer through the back of the factory fog housing and instead of a fog housing lens, there would be a projector shroud like shown above. Everything would be mounted to the back of the factory fog light housing so mounting would be stock and I'd still retain that stock adjustment screw. It'll be a winter project so I'll get some pics up when it comes to light!
  17. Nov 8, 2011 at 1:05 PM
    #37
    AsianAnts
    AnT
    you may be able to pull it off! but my concern would be if the mini gatling shroud will cover the remaining chrome parts of the fog reflector bowl... and then the other thing is that the blazer fogs has the 2 mounting posts already... is the shroud going to cover that?? OR what i would do is simply cut those 2 posts off...
    Pugga, very good idea. I want to see this :)
  18. Nov 8, 2011 at 1:09 PM
    #38
    Pugga
    Massachusetts
    Stay tuned... :D
    Hopefully I get some dimensions of the mini gatling shroud from TRS. I'm assuming whatever does not get covered by the shroud would be blacked out and so far behind everything it wouldn't really catch your eye unless crouched down at eye level looking straight in (assuming the shroud doesn't cover everything). As far as the mounting tabs, my dremel tool will make short work of those :cool:
    I'm hoping to epoxy the Blazer projector into the shroud and then epoxy the shroud back to the fog light base. The Blazers would also be supported at the back where they poke through the back of the housing so they'd have 2 points of support.
    In my head this works out great... we'll have to see how realistically possible it is. I think I'm sold though, I'm done procrastinating!
  19. Nov 8, 2011 at 2:13 PM
    #39
    AsianAnts
    AnT
    yea, i can picture it in my head too.. and im sure its possible! :)
  20. Nov 9, 2011 at 4:23 AM
    #40
    Pugga
    Massachusetts
    I hadn't thought about that... I don't have a set of blanks or know how they mount. The only issue I can see with the blanks is the lack of adjustment where as mounting the Blazers to the fog light housing would still allow me to retain the factory adjuster screws. The blanks might hold them more securely though. :notsure:
