Blazer Fogs in Factory Fog Housing
Discussion in 'Lighting' started by Yota Toy, Aug 13, 2011.
  1. Nov 13, 2011 at 2:58 PM
    #41
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Parts ordered :D
    They should ship tomorrow, I'll start another DIY thread with the retrofit. I'll probably do it the weekend after Turkey day.
  2. Nov 13, 2011 at 3:00 PM
    #42
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    :woot:
  3. Nov 24, 2011 at 10:45 AM
    #43
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
  4. Nov 26, 2011 at 12:04 PM
    #44
    shweller
    shweller Well-Known Member
    Corona
    2010 Tacoma TRD Sport SB 4x4
    PoP 'N' Lock Satoshi Grill (Did it Myself) DSM UCA's (Desert Products) FXR 1.1 w/Gatling Gun Shrouds Phillips 85122 Method Racing Wheels HID Hella 500's behind Satoshi grill Fog Light Anytime Illuminated 4x4 Switch Ultragauge PIAA 510"s King Coilovers w/resi's Rear TSB Leaf Packs All Pro Sliders Bolt on sliders 255/75 R17 BF Goodrich Mudders Spidertrax wheel spacers Neoprene arm rests Weathertechs Wet Okoles w/TRD Allpro Ofrroad Apex bumper and IFS skid plate
    Noob question but how did you get the cut off line level as far as the rotation of the projector in the light housing? I am looking to get in on the GB for a set blazers and am looking to do the retro myself....
  5. Nov 26, 2011 at 12:08 PM
    #45
    AsianAnts
    AnT
    i lined up the projector along the lines of the fog light...
    if you look a the lines on the back of the housing, i made sure the projector mounts should be parallel.
    In the OP, the first pic shows the lines on the back of the fog light housing. in pic 3, it shows the projector mounts. those mounts should line up with the lines on the back of the fog light housing
  6. Nov 26, 2011 at 1:52 PM
    #46
    shweller
    Corona
    Thanks for the info, I believe I just asked you the same question on another thread (noob move):facepalm:.
  7. Dec 7, 2011 at 3:18 PM
    #47
    Cuda444
    Cuda444 Well-Known Member
    New England
    TRD Off-Road
    Access Limited Bed Cover, URD Short Shift Kit, 25% Tint all around, WeatherTechs, Kenwood DNX-6160, 2 - IDQ10 sub, Hybrid Audio Clarus 6.5's, JL 500/1, JL 300/2, Mr.Marv Enclosure/Amp Rack, Morimoto Stage III Retro Headlights, Blazer Fog Retro
    Curious as to the jig you made up to enlarge the hole. Certainly no easy feat going from a big hole to a bigger hole. Could you elaborate please?
  8. Dec 7, 2011 at 3:21 PM
    #48
    AsianAnts
    AnT
    I used this:
    then this to enlarge:
  9. Dec 7, 2011 at 3:28 PM
    #49
    Cuda444
    New England
    TRD Off-Road
    Hmm interesting. Thanks for the quick reply. Does that work like a normal hole saw? How did you center it over the existing hole?
  10. Dec 7, 2011 at 3:32 PM
    #50
    AsianAnts
    AnT
    the first picture shows a comparison with a fog light already modified and another that is still stock... i use the metal cutting wheel to cut off the plastic part the holds the bulb into the fog light... once done, i use the sanding tool to enlarge the hole.. I was quite slow at first with the drum sanding tool because i wanted to make sure the circle was evenly round..
    I think op said the hole is a little bit larger than 1 3/4"... i didnt have a hole cutter soo thats why i did what i did....
  11. Dec 7, 2011 at 5:34 PM
    #51
    Pugga
    Massachusetts
    You can use a hole saw if you're careful and sort of eye ball it to center it over the existing hole. The drills with a level bubble on the top do help. If you slightly oversize the hole, the hole doesn't need to be perfect, it just needs to be perfect when you JB Weld the projector in place. Dremel also makes a bit that looks like a drill bit but is made to cut sideways. It's very effective for cutting apart the fog light housing.
  12. Dec 7, 2011 at 5:54 PM
    #52
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    .02...Router bit.:thumbsup:
  13. Dec 7, 2011 at 6:06 PM
    #53
    Pugga
    Massachusetts
    Thanks, I had no idea what it was called but they are handy!
  14. Dec 10, 2011 at 9:42 AM
    #54
    shweller
    Corona
    Yota Toy, did you use the TRS 9006 harness? I have factory fogs and amleaning towards using the harness for added protection although I can just pluginto the factory plugs. Advise?
  15. Apr 4, 2012 at 9:35 AM
    #55
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Sub'd for this summer :)
  16. Apr 28, 2012 at 4:48 PM
    #56
    babyboi2284
    babyboi2284 Well-Known Member
    Brian
    Lockport, Louisiana
    09 Barcelona Red X-Runner
    LS 6k projectors w/ white halos, 6k fogs, T-Rex Angry Lids, NST SSK, Coupe Shift Knob, BHLM, LFM, DLM, FLM, JL 500/1 amp, JL 10"w6v2, subX wanna be made by me, Magnaflow muffler, 5% tint, k&n drop in filter, Craven Speed Stubby, map light mod
    Is there a write up to open the fog light housings? Or tips?
  17. Apr 28, 2012 at 6:54 PM
    #57
    Pugga
    Massachusetts
    Check this out:
    http://www.tacomaworld.com/forum/lighting/187831-fog-light-retrofit.html
    I made a step by step write up. I found it was easiest to use a hack saw and work my way around. To open up the fogs, you have to cut them, they don't come apart like the headlights. I used a dremel for one and a hack saw for the other one. I found that the hacksaw made a much cleaner cut and was easier to put back together.
  18. Apr 29, 2012 at 1:44 PM
    #58
    babyboi2284
    Brian
    Lockport, Louisiana
    Thanks man. I have a hi/lo kit that doesn't require cutting into the rear of the housing I was just wondering if the fog clear lens can be taken off without cutting it off
  19. Apr 29, 2012 at 3:07 PM
    #59
    Pugga
    Massachusetts
    Unfortunately, there's no way to get just the lens apart without cutting it.
  20. Aug 18, 2012 at 8:38 PM
    #60
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    has anyone ever tried this yet?
