bleed brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeff2020, Mar 24, 2025.
  1. Mar 24, 2025 at 8:45 AM
    Jeff2020
    Jeff2020 [OP] Active Member
    Is it OK to bleed in stages? Like two front wheels in one day and the two rare wheels a couple of days later?
  2. Mar 24, 2025 at 8:48 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Always start with the wheel farthest from the reservoir and work closer. Why not just do all 4...takes a matter of minutes.
  3. Mar 24, 2025 at 8:51 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I think the better question is why are you doing this?
  4. Mar 24, 2025 at 10:24 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Are you just changing fluid? Or did you change the brake caliper(s)
    either way. Do them all at once. Do you just want 2 wheels to brake rather than 4.
  5. Mar 24, 2025 at 10:25 AM
    Jeff2020
    I have got sever thumb arthritis. So, I got give it a rest. If I have to do all 4, I will, but prefer to do it in two separate days if is advisable.
  6. Mar 24, 2025 at 10:32 AM
    airforceb2cc
    Don
    KCMO
    That makes sense. If you don't drive it between bleeds and you don't have air in the system (flush only) then you are fine. If you are driving it between, you can contaminate the new fluid with the junk in the two lines you don't bleed. Maybe offer the neighbor a beer to run the bleeder screw while you pump the brakes?
  7. Mar 24, 2025 at 11:37 AM
    Sungod
    St Augustine
    Are you bleeding them just as a matter of practice? Replaced calipers? Fluid change? Some situations may be more logical than others to wait a day or so. Assume you are not doing this by yourself?
  8. Mar 24, 2025 at 1:24 PM
    Jeff2020
    All good, I think I got to get rid of old fluid. I thought I could do it by myself. If not, then I have to take to the dealer which is going to take the whole day being 25 miles away.
  9. Mar 24, 2025 at 1:37 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Check out this video from the Maintenance Map thread.
    https://www.youtube.com/watch?v=iAgXYLiIApU
    Chew likes this.
  10. Mar 25, 2025 at 5:40 AM
    Jeff2020
    Thanks, I watched the video several times and it looks not that hard and doable by one preson. I thought that I had to take the wheels off!
  11. Mar 25, 2025 at 5:45 AM
    Sungod
    St Augustine
    It is much easier to bleed your brakes with 2 people. One pumping the brakes and the other opening and closing the bleeder. You don't have to remove the wheels, but it is easier when you have the extra room. For what you are doing, you can do it over several days. Just make absolute sure that you keep the reservoir full at all times. You drain the reservoir and you are bleeding all of them at one time.
