Bleeding brakes. Help
Discussion in 'Suspension' started by Socalrunner, Apr 29, 2011.
  1. Apr 29, 2011 at 11:11 AM
    Socalrunner
    Socalrunner [OP] Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    So i just install longer brake lines and i can not get my brakes to bleed on my 2011 tacoma. I got some air to come out but i already ran about 2 quarts of brake fluid through and it will not let the air out.
  2. Apr 29, 2011 at 11:12 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    what wheel are you starting at?
  3. Apr 29, 2011 at 11:15 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Is your basic bleeding technique right?
    My Haynes guide says if you get air in the master cylinder, it means a trip to the dealer for them to fix using special equipment.
  4. Apr 29, 2011 at 11:16 AM
    David Tarantino
    N.J.
    08 tacoma
    start at r/r go to l/r then r/f l/f have somone in the truck pump up the brakes then hold them down and open bleeder slowly
  5. Apr 29, 2011 at 11:19 AM
    Socalrunner
    Glendora
    Icon Coilovers
    I tried the link above with no luck and basic bleeding techniques. I dont see how air got into the mastercylinder or abs module. Will gravity bleeding work?
