bleeding brakes on 2nd gen Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paul7475, Apr 3, 2015.
  1. Apr 3, 2015 at 2:56 PM
    paul7475
    paul7475 [OP] Active Member
    Paul
    So Cal
    2015 TRD Sport
    Square head hose clamp tail gate protector. Bed mat. Cargo divider. Shell. De-badged and de-stickered.
    What is the pattern for bleeding brakes on a newer Toyota?
  2. Apr 3, 2015 at 3:53 PM
    schleygo
    schleygo Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    I always thought it was bleed the one farthest away from brake pedal first
    Then drink beer.......
    D50boy likes this.
  3. Apr 3, 2015 at 3:55 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    ^ truth
    the bit about doing the furthest from brake pedal is true too.
  4. Apr 3, 2015 at 4:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and if you are lucky and have an 09+ TRD OR 4x4 (a truck with the electric brake booster) you can literally bleed 4 fully dry lines in the matter of about 5 minutes cus it will literally pump fluid through the line for you without having to pump the brakes.
  5. May 20, 2015 at 8:12 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    So do all 09+ trucks have the booster
  6. May 20, 2015 at 3:05 PM
    tasnowma
    tasnowma Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    :rofl:
  7. May 20, 2015 at 3:20 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Pattern is same on every vehicle: Back Right, Back Left, Front Right, Front Left. You do the furthest from, to closest.
  8. May 20, 2015 at 4:24 PM
    nd4spdbh
    SoCal
    No Only 09+ TRD Offroad 4x4's
  9. May 21, 2015 at 7:40 AM
    TunnelDV
    TunnelDV Well-Known Member
    Derek
    Denver
    10 4Dr Tacoma White
    Get speed bleeders. Makes the job easy and only required one person. Someone posted a very good how-to with part numbers. They offer steel and stainless steel. After seeing the condition of the old valves, I am glad I paid for the stainless speed bleeders.
    Derek V
  10. May 21, 2015 at 10:09 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    anyone know where the thread is?
  11. May 21, 2015 at 8:32 PM
    TunnelDV
    Derek
    Denver
    10 4Dr Tacoma White
