Bleeding brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JRinIowa, Dec 14, 2023.
  1. Dec 14, 2023 at 8:00 PM
    JRinIowa
    JRinIowa [OP] Active Member
    So, having replaced both the front pads and rear shoes, and adjusting the shoes to scuff and then back off to free, I decided to bleed the brakes. I have a MityVac vacuum bleeder that I have used successfully for years. I pulled about 1 1/2 Oz of fluid from the right rear and got clear fluid, topped of the reservoir and moved to the left rear. I started pulling LOTs of air, pulled 3 Oz of fluid and the bubbles never stop. I've got a tight seal on the bleeder and can only believe I am sucking air around the bleeder threads. Any thoughts? I'd like to solve this before I move to the front.
  2. Dec 14, 2023 at 8:05 PM
    Bishop84
    Bishop84 Well-Known Member
    The flow from the rear bleeders is slower than the mityvac, so it comes out in staggered flow, looks like air but its not.
    Air has to be induced, if you had air you would have noticed before the bleed.
    So unless you ran the master low, or cracked any of the lines, its fine.
  3. Dec 14, 2023 at 8:26 PM
    TacoTuesday1
    FL
    air gets past threads.
    the tool is pressure bleeder.
    1schoir likes this.
  4. Dec 15, 2023 at 3:33 AM
    JRinIowa
    Figured. Thanks.
  5. Dec 15, 2023 at 3:34 AM
    JRinIowa
    Pressure bleeder on the way. Thanks.
  6. Dec 15, 2023 at 5:42 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Which bleeder did you go with?
  7. Dec 15, 2023 at 7:18 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    FWIW, I've been using the Motive Power Bleeder for about 20 years and it has never failed me.
    https://www.amazon.com/Motive-Produ...fos.17d9e15d-4e43-4581-b373-0e5c1a776d5d&th=1
    I always rinse it out after use.
    I just used it on my '06 when replacing my flexible brake lines with braided stainless steel flexible lines and it worked flawlessly.
    https://www.tacomaworld.com/threads/stainless-steel-flexible-brake-lines.813273/
    The adapter that goes on top of the master cylinder makes a leak-proof seal with the small chain links tightened down. Adjust the air pressure to about 15 psi, keep an eye on the brake fluid level as you are bleeding each caliper and you're good to go. Don't let the master cylinder run dry or you may have to deal with air in the ABS.
  8. Dec 15, 2023 at 7:30 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Speed bleeders.
    Rob MacRuger likes this.
  9. Dec 15, 2023 at 11:06 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
  10. Dec 15, 2023 at 2:48 PM
    TacoTuesday1
    FL
    motive is what dealerships, independent specialists, and DIYers use
    dealers also usually have at least one factory pressure bleeder that does the same thing, electric or compressed air power for constant unlimited pressure automatically
    required as minimum tooling by the manufacturer to be allowed dealer license
    but they can break and are expensive
    so if a shop has 30 techs and one $1000 broken machine
    everyone ends up buying a Motive to have as backup, if the dealer doesn’t buy them
    $60 much cheaper than $1000+
    or if another guy is busy using the machine when you need it
    there may be other adapters that fit 2G but one is Power Probe BA10
  11. Dec 16, 2023 at 1:40 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I have a motive pressure bleeder but heard negative reviews on the master cylinder cap not creating an adequate seal, good to hear you have positive experiences with yours. so I made my own cap and tested the pressure, which is all good. I never used it yet.
  12. Dec 17, 2023 at 7:52 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    If you think you are sucking air through the threads of the bleeder pull the bleeder and wrap the threads in teflon tape. This will seal the threads and also protect them from rusting fast.
  13. Dec 17, 2023 at 9:38 AM
    JRinIowa
    SMotive Pro, used off Amazon, and a 43mm clamp-on cap from the same vendor. The cap had already arrived and passed a test fit.
    gkomo[QUOTED] likes this.
  14. Dec 17, 2023 at 9:57 AM
    vtdog
    vtdog Well-Known Member
    NH
    I realize its not a popular choice here, but I paid a local shop about $ 85 to flush and bleed the brakes. They had the "special" ABS bleed unit and it just seemed like the easiest route to follow. I changed out the front pads/rotors myself at 90k and had the flush/bleed done after that.
  15. Dec 17, 2023 at 10:26 AM
    JRinIowa
    I totally understand, and even being a DIY kind of guy, I sometimes take my car or truck into the dealer, whether it's something I'm not currently tooled up for, or, if I just don't feel like subjecting myself to the hassle of doing my own work on a particular day.
  16. Dec 17, 2023 at 10:28 AM
    JRinIowa
    I've considered that.
  17. Dec 17, 2023 at 10:36 AM
    Red13
    Red13 Active Member
    Truckee, California
    2013 DCLB Tacoma 4x4
    Same. Used it for years, replaced the hose once as it was degrading (due to age). Motive sent me new one for free. No problems with the cap. I never put fluid in it, just used it to pressurize the system, adding fluid to the reservoir as needed.
  18. Dec 17, 2023 at 10:55 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Last brake job I installed SpeedBleeders. Takes a little time, but single handed bleed job. Simple, inexpensive, can bleed brakes anywhere.
    gkomo likes this.
  19. Dec 17, 2023 at 3:36 PM
    TacoTuesday1
    FL
    or anti sieze and noting K factor regarding torque in future
  20. Dec 23, 2023 at 11:56 AM
    JRinIowa
    Well, got the Smotive pressure bleeder and cap out today and finished the bleeding. Got just a little bit from the driver's rear. Then got to the driver's front and got about a cc of solid air out. Now, the only pedal softness comes from the 20 year-old brake hoses. I'm not running 100+ mph on a track so I can live with that as long as they don't explode. Overall, I've put about $600 into redoing the brakes and probably couldn't beat that at any service shop.
    Micbt25 likes this.
