Bleeding breaks?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrissteffen599, Sep 11, 2014.
  1. Sep 11, 2014 at 1:21 PM
    Chrissteffen599
    Chrissteffen599 [OP] Well-Known Member
    Texas
    02 tacoma
    Bilstein 5100 all around Allpro front and rear bumpers Trailgear turn signals Hella 700ff HID conversion
    So I went and got a tune up for my taco and they told me that I need to bleed and flush my brake fluid. Is that something that really needs to be done or are they trying to squeeze money out of me?!? Also, would it fix my squeaky brakes?!
  2. Sep 11, 2014 at 1:33 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    We can't know the answer based on the little info we have from you.
    How many miles on the truck? When was the break fluid last changed?
    The squeky brakes will only be fixed with new pads.
  3. Sep 11, 2014 at 1:42 PM
    RND2
    RND2 Well-Known Member
    In my head swimming around
    12 DCSB
    RCD 4"
    not going to fix the squeek.
    is the fluid clean or dirty and how old?
    brake fluid is like a sponge and will absorb moisture.
    flush and bleeding is easy
  4. Sep 11, 2014 at 3:12 PM
    Chrissteffen599
    Texas
    02 tacoma
    So I bought it used but I doubt it's ever been done or if it has, it's been a long time. So, I guess I should probably go ahead and do it eh? What are the side effects of never doing it out of curiosity?
  5. Sep 11, 2014 at 3:24 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    The fluid can be tested.They sell strips to dip in the fluid to test for contaminates.Maybe the shop tested it or found something not right.Check it yourself.
  6. Sep 15, 2014 at 1:25 PM
    So Many Roads
    So Many Roads Member
    New fluid = improved braking (assuming the current brake fluid is more than 30,000 miles old). Speed bleeders or vacuum brake bleeding kits make it a pretty easy job.
