Blend Door Actuator
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tsean, Aug 5, 2023.
  1. Aug 5, 2023 at 6:41 PM
    Tsean
    Tsean [OP] Well-Known Member
    Tsean
    Im having my AC cold and hot once while I figure it is my blend actuator needs to be replaced or is the anything else should I look for
  2. Aug 5, 2023 at 7:16 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The potentiometer on the temp control dial also seemed to have issues on 1st gens, when it goes to hot can you get it to go back to cold by messing with the temp dial a bit?
    Sklar likes this.
  3. Aug 5, 2023 at 8:56 PM
    Tsean
    Tsean
    Ok thanks perfect much appreciate for your inputs I’ll try to troubleshoot however what it does the ac is fluctuating time to time so I don’t if it’s actually my air mix serví or blend mode on my under driver side
    Dm93 likes this.
