blew a rear strut
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Jan 3, 2011.
  1. Jan 3, 2011 at 9:01 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    not sure exactly what caused it but i blew the driver side rear strut
    it's been very cold out so maybe the seal froze then when i backed up it popped out, either way it spewed the oil out
    i was wanting to do a full lift next year, so i don't want to have to buy new struts now
    anything wrong with swaping in a non TRD rear strut for the time being? i'd just like to get one from a junk yard if i could
    or even just buying a crappy replacement shock for now
    any advise would be great
    thanks
  2. Jan 3, 2011 at 9:03 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    if its just a temporary fix then go for it. it may ride a little weird if the suspension is different on both sides on the rear of the truck but if you can live with it till you get the new stuff then i dont see a problem if you dont.
  3. Jan 3, 2011 at 9:19 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    x2. If you're looking in a junk yard, maybe get the non-TRD used for both sides in the rear so it'll at least be the same side to side. If you've had the TSB done your springs may be a little bouncier with non-TRD shocks but it'll get you by til you get your lift.
  4. Jan 3, 2011 at 9:27 AM
    vantaco
    ok ya that's what i was thinking too
    what's TSB?
  5. Jan 3, 2011 at 9:50 AM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I don't know if I am understanding right? Did you blow a rear factory Bilstein shock?
  6. Jan 3, 2011 at 9:54 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    He's a first gen
    Technical Service Bulletin, but it doesn't apply to you.
    Yes
  7. Jan 3, 2011 at 9:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I was tryin to figure out how OP has a "STRUT" on the rear of a Tacoma. :p We're gonna need pics of this...........
  8. Jan 3, 2011 at 10:08 AM
    Pugga
    Massachusetts
    F-150 Mod
    Damn, guess I'll have to read a little more next time... :eek: Good catch, but it simplifies the solution a bit.
  9. Jan 3, 2011 at 10:13 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    LOL he don't have struts out back he has shocks.
    I wonder if it would even be worth it to go to a junk yard to get a shock. they might want like 30 bucks a shock. You can get some 5100's for not much more then that.
  10. Jan 3, 2011 at 10:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I can show you a 1st gen with rear coilovers. :p
  11. Jan 3, 2011 at 10:23 AM
    JLee
    Jerry
    Bay Area NorCal
    LOL so could I :D
  12. Jan 3, 2011 at 10:34 AM
    vantaco
    shock/strut, we all know what i'm talking about
    yes, as noted above, it was the factory TRD bilstein shock
  13. Jan 3, 2011 at 10:37 AM
    JLee
    Jerry
    Bay Area NorCal
    Just buy some 5100's
  14. Jan 3, 2011 at 10:39 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    yes, hence the :p IMO, 2 new rears would be the ticket. If one blew then the other can't be that much better off.
  15. Jan 3, 2011 at 11:18 AM
    vantaco
    ya i know...and 5100's are what i'm going to get
    and new fronts, coils and leafs...but that's money i don't have right now....
    diamond rings are expensive lol
    could i put 5100's and run then with the stock leafs (which are pretty flat), i don't want to cause extra wear on the 5100's and wear them out prematurely
  16. Jan 3, 2011 at 11:43 AM
    Killer
    Mobile, Al.
    I was asking about the shock because I am about to put some 5100s on my sons 1998 Xtended Cab. I was going to keep the Factory Bilsteins for spares since I only have 22,000 miles on the truck.
    But, I have a soft spot for people that served in the military. So if you have served in the military, I will give them to you.
  17. Jan 3, 2011 at 11:46 AM
    vantaco
    nope, no military for me. plus shipping will cost more than i can get a used/junk yard set for here
    thanks anyways
