Blew my transmission yesterday
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaveCanuck, Feb 24, 2014.
  1. Feb 24, 2014 at 2:04 PM
    DaveCanuck
    DaveCanuck [OP] Well-Known Member
    Dave
    Canada
    2011 SR5 V6
    First off, it's a high mileage Tacoma... 256,000 miles. 1997, 2.7 5spd.
    We got hit with a sizeable snowstorm this past weekend up here on the Canadian west coast. I always love an opportunity to drive in 4x4 mode, but I noticed that when I shifted it back into 2 wheel drive, there was a vibration I'd never experienced, as well as a noise I'd never heard.
    Things deteriorated VERY quickly and suddenly something gave way, and it sounded like there were rocks grinding away somewhere underneath inside my drivetrain, and ultimately not I can't even move... there's just spinning. When I'm sitting in idle in neutral the grinding sound is there, but when I push in the clutch it's quiet.
    Unfortunately the snow is so bad here even the tow trucks aren't operating. So I can't get it into the shop to have it looked at.
    Anyone want to venture any guesses of the severity of the issue?
  2. Feb 24, 2014 at 2:48 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did the manuals have the planitary problem as well? I've only toasted one and it was an auto.
  3. Feb 24, 2014 at 2:49 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I had a similar failure in a 5 speed 2wd 1978 toyota. Bearing on the transmission countershaft failed. It still worked in 4th gear. Get another transmission was my solution.
  4. Feb 24, 2014 at 2:52 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    I wonder if it's a job that can be done for under $1000.
  5. Feb 24, 2014 at 2:54 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    This may be unrelated, but I recently had everything switched to synthetic.
    Not long after I noticed that when I downshifted, especially down to 1st it ground the gears. I had me suspecting the slave cylinder was leaking.
  6. Feb 24, 2014 at 2:56 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    No planetaries
    Get another trans
  7. Feb 24, 2014 at 10:36 PM
    mech160
    mech160 Well-Known Member
    50th
    1995.5 Tacoma
    I had the same experience, I think it was Amsoil Synthetic Gear Oil. After the conversion, trans has not shifted smooth since. Master/slave very low mileage. (W59 2WD)
  8. Feb 24, 2014 at 11:06 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Small world. Same deal, 78 Corolla, but the main input shaft bearing went also. Split it myself and fixed it. Rollin again for about $125 bucks work of gaskets,bearings and oil. Failed right after a clutch replace,,just couldn't take the added pressure on it with new parts I think. Couldn't have been me sidestepping the little whizbang 1600 hemi once in a bit.
    Sucks when they go rock crusher all of a sudden.
    Yup, new/used tranny, flywheel face, pilot bearing, throwout, disk and plate. Might as well Dave.
  9. Feb 25, 2014 at 7:39 AM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Yes, that was my initial instinct. It's a high mileage vehicle, though.
    Even a good used one would suffice.
  10. Feb 25, 2014 at 8:46 AM
    CR, WA
    stock
    High mileage or HARD mileage,,you still have 300K yet to go,,maybe more.
    I bought that car with 275k on it and put on 170k and it was still ticking when it parted from me.
  11. Feb 25, 2014 at 9:34 AM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    It's very possible there was some hard mileage on it.
    The guy I bought it from is an acquaintance and he used it as a
    Personal and farm vehicle. He might have had heavy loads, and a
    Fair bit of 4X4'ing.
  12. Mar 2, 2014 at 2:11 PM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Well, back on the road again, after an expensive repair. Replacement gearbox, and also a clutch kit.
    The truck was repaired by a different mechanic than the one who serviced it last time with the complete fluid change.
    A mechanic friend of mine who lives in a different province suggested the wrong fluid might have been used for the gearbox. I just looked at the invoice... hard to make out the writing but it's possible gear oil was used in the gearbox. It was a full switchover... everything to synthetic... engine, gearbox, transfer case, rear diff...
    Also, this same friend of mine learned that my shifting practices while driving might have contributed. I have a habit of downshifting into 1st while driving, holding the clutch in for most of the stopping effect, and shifting into 1st at the end. He advised me this was a terrible practice.
    The next mechanic (who did the repair) noted bits of metal in the fluid, and 1st gear was the issue.
    He used 75-90 in the gearbox and transfer case. I'm HOPING this is the right type!!!
  13. Mar 3, 2014 at 5:44 AM
    CR, WA
    stock
    Knew that one was going to be expensive, yikes.
    A competent man behind the wrenches is always a good thing. Repair jobs has made a surge in the us,,imagine that.
    Personally, I would go about 500-1000K,,or maybe a bit further and swap the fluids again on your trans, transfer case,and your rear diff. Since it is a unknown transmission??, you really don't know what they ran for fluids in there or how they treated it, drove it.
    Yup, riding first gear syncros hard and all that built up rotating mass/building very quick RPM's right at the end trying to pull the lever in is never a good thing. Think Friction welding and Youtube that. Try to break that habit, you will save a ducket or two.
    Panning for mixed metal is what I call the grey residue. Have dried that stuff out before, and put it under a 60x stereo scope,,lotsa rainbow colored metal flakes. The full synthetic was a smart answer for the wrench turner. Go about 500-1000k and swap in fresh syn, then run it out there 40-50k and then take a oil sample. Should be crystal clear or close,,if you did your homework,,:)
    75-90,,yup,,he was right. Give it a few/5 minutes to warm up and warm the fresh fluid in the trans. It might feel a little "hesitant to shift" when cold,,until some miles and heat are on it. You are breaking in a new clutch and throwout bearing as well.
  14. Mar 3, 2014 at 6:13 AM
    BamaToy1997
    Bill
    Navarre, FL
    GOTTA be a typo there! Haha. 500-1000K? That is some SERIOUS mileage. lol. But yes, when breaking in a replacement transmission I would recommend in the 500-1000 mile range to replace the fluid, and send in a sample of the old fluid in to be tested. See if things look good there.
  15. Mar 3, 2014 at 6:28 AM
    CR, WA
    stock
    Sunsabitchin Bumfasus!
    yeah typo.
    500-1000 miles US. lol.
  16. Mar 3, 2014 at 8:28 AM
    DaveCanuck
    Dave
    Canada
    2011 SR5 V6
    Thanks guys,
    Well if all that wasn't enough, now after some searching on this forum and on google, my latest paranoia has to do with the TYPE of 75 - 90 was put into the replacement gearbox... GL4 or GL5... not sure. It seems that GL4 is the one recommended as the other is hard on the brass parts? I don't know anything about that, could someone on here weigh in?
