Blew ‘er up on the trail last night.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cereal_killer, May 8, 2022.
  1. May 9, 2022 at 6:35 PM
    #161
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    @CygnusX191 :boink: Better be careful out there. Even with a catch can.
  2. May 9, 2022 at 6:36 PM
    #162
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In all honesty, everyone wants a diesel Taco, but that D4-D conversion just sits.
    The big deal here is what @Cereal_killer wants to do about the Christmas tree that will be on the dash. No one has pulled off a swap yet, AFAIK, that did not used a standalone ECU.
    I hope there is an easy route, but I am struggling to see it.
    Kev250R and Cereal_killer[OP] like this.
  3. May 9, 2022 at 6:40 PM
    #163
    Cereal_killer
    Cereal_killer [OP] Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    @Dirk Diggler the plan is to reply to every idiot asking how to make their exhaust sound more like meso’s truck or tacomabeast (sorry to put those two together in the same sentence but we’ve all seen the threads) with an exhaust sound clip and whatever bullshit hashtags I come up with off the top of my head at that time.
  4. May 9, 2022 at 6:40 PM
    #164
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
  5. May 9, 2022 at 6:44 PM
    #165
    Cereal_killer
    Dan
    Yeah
    As I mentioned above a stand alone cluster will replace the Toyota dash. I don’t have time nor the personal desire to deal with that level of integration. Slapping junk yard LS’s in things is as basic as it comes, there will be no new developments from me here. I’m just an idiot with a welder and efilive.
    About the most I see electronics wise is taking manual control of the ADD, do you have any reading material on that subject (motor swap related or not)? Research begins now!
    tonered[QUOTED] likes this.
  6. May 9, 2022 at 6:46 PM
    #166
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. Your post came in as I was typing mine. You seem to have all of that sorted.
    I really hope that it works for you. If it does, it may finally open the flood gates.
    BTW, I am curious WTF that pin / bolt in you pan is from. It is stumping me.
  7. May 9, 2022 at 7:22 PM
    #167
    Cereal_killer
    Dan
    Yeah
    @tonered thats an oil squirter for the skirt of the piston to not have to rely on splashing / dripping.
    (Random google image, not a 2GR)
    Slashaar, tonered and skeletron like this.
  8. May 9, 2022 at 7:25 PM
    #168
    Schillio
    Schillio Member
    Bill
    Maine
    2017 TRD OR AT
    Lift, skids, sliders, 4.88's, KDMax 6.0
    So just thinking out loud here, and there may be several reasons why not, but what if you could temporarily close the vent line in between the pcv and intake while on an incline or camber? Maybe even wire in a simple inline solenoid valve you could actuate via a switch on your dash when you need to? Once past the obstacle and level, idle for a bit to let the heads drain, open the solenoid valve, pcv opens and presure released.
    popop likes this.
  9. May 9, 2022 at 7:33 PM
    #169
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Good question. I’m also wondering if right side camber is okay, where left side camber is a no no. Or vice versa.
  10. May 9, 2022 at 9:06 PM
    #170
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Someone just needs to make an aftermarket valve cover with the pcv on the outboard or inboard side like most correctly engineered engines....
  11. May 9, 2022 at 9:09 PM
    #171
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    You can swap the front add for a FJ tube which effectively locks the front full time. Than just get a manual transfer case that has full internal disconnect like a nv231/241 like i have. throw a 4l80 or 6l80 in and your set. but yeah most standalone ls harness's only need a power wire, brake light wire, ignition and power. Only issue you would run into is if any of the factory systems quit playing ball when you pull the engine and the cluster.
  12. May 10, 2022 at 5:37 AM
    #172
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks!
  13. May 10, 2022 at 6:17 AM
    #173
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Damn dude, who pissed in your cheerios? And why did you decide to take it out on this thread?
    Im sure Ive been damn close to 100 miles from pavement before (no need to worry yourself, it was in the lower 48). And I know for a fact Ive been at least 35-40 miles from cell service as the crow flies. Which corresponds to probably 40-45 miles from pavement as the crow flies, if you really want to measure it that way.
    Right, how could I forget..
  14. May 10, 2022 at 6:18 AM
    #174
    SR-71A
    Zack
    Southern Maine
    Anyway back on topic.. damn dude, that sucks. My vote is always for a 4 cyl Cummins swap :D:D
  15. May 10, 2022 at 3:47 PM
    #175
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Cool story bro, I owned a Jeep once and the only thing it was good at was crawling over shit in low range, traded it for a new 2003 Tacoma when the transmission started going south at 80k miles
  16. May 10, 2022 at 4:02 PM
    #176
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
  17. May 10, 2022 at 4:21 PM
    #177
    PokerPilot
    PokerPilot Well-Known Member
    Sorry to hear OP. Just curious, how many miles were you able to get on that motor before this unfortunate incident?
  18. May 11, 2022 at 2:39 AM
    #178
    Cereal_killer
    Dan
    Yeah
    It had 67k with meticulous maintenance. Barely even broken in.
  19. May 11, 2022 at 4:29 AM
    #179
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    I would think that if there was a aftermarket oil pan with baffles in it ,and deep sump this may be avoidable.
  20. May 11, 2022 at 5:23 AM
    #180
    bush rat
    bush rat Well-Known Member
    BC
    2022 6MT Access Cab
    “off road” issues are easily fixed with a hair dryer.
