BLHM
Discussion in 'Lighting' started by francis1291, Feb 7, 2011.
  1. Feb 8, 2011 at 7:40 PM
    #41
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Yeah, I used Rustolium mate clear coat, the only thing is that after using the Rustolium mate clear you should rinse it because it gets a white film but rinses right off.
  2. Feb 8, 2011 at 7:44 PM
    #42
    francis1291
    francis1291 [OP] Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    i just put one coat of krylon crystal clear clear coat on it....what are some thing and tips for when i seal them back? Do i put a thick bead on sealent on on thin? If i remember right someone said taht i need to clean the projection bowl and then inside of then lens. is that true
  3. Feb 8, 2011 at 7:49 PM
    #43
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
    NO! If you didn't touch either and they are clean don't touch them. If you do you will run the risk of having wipe marks. I did this with one of the first pairs and looked ok but when direct light would hit you could see the wipe marks. I don't use a lot of sealer I just make sure it is even.
  4. Feb 8, 2011 at 7:54 PM
    #44
    francis1291
    ok well thanks....a buddy said if they are dirty i could used compressed air cuz i really dont remember if i touched them or not but i will look to see if i see dirt and finger prints...what if i do see finfer prints and stuff how do i get rid of them?
  5. Feb 9, 2011 at 2:01 PM
    #45
    francis1291
    when i put the bezel back in the oven like the how to says to do i need to put the blinkers on also? or just bezel?
  6. Feb 9, 2011 at 11:06 PM
    #46
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    The blinkers? You mean the lenses or something? If so, no, you dont put them on to bake.
  7. Feb 10, 2011 at 3:23 AM
    #47
    francis1291
    DONE!!!!!! all ig got to do is put them in...is there any way to make sure i sealed them good b4 i put the back on truck?
  8. Feb 10, 2011 at 3:40 AM
    #48
    francis1291
  9. Feb 10, 2011 at 3:40 AM
    #49
    francis1291
  10. Feb 10, 2011 at 3:49 AM
    #50
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have no clue what is going on here:confused:
  11. Feb 10, 2011 at 6:28 AM
    #51
    Tidrow
    Tidrow Well-Known Member
    Austin
    PreRunnin' 08
    BHLM, All Black grill, Fog light Mod, AFE pro dry, 20% tint, Weathertechs, Kenwood deck, Bridgestone AT Revo 2
    looks good bro :thumbsup:
    Can't wait to see em on the pickup.
  12. Feb 10, 2011 at 6:32 AM
    #52
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Nice job! No way to tell, but if you're worried, just run an extra bead of silicon around the seam.
  13. Feb 10, 2011 at 8:00 AM
    #53
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Look Great!
    I'd like to request some night shots with only the parking lights and/or turn signals on. Curious how much light is coming out. I'm going to redo mine this spring and tempted to darken those lenses like you did.
  14. Feb 10, 2011 at 8:08 AM
    #54
    francis1291
    ill get some night shots soon for yall
  15. Feb 10, 2011 at 8:08 AM
    #55
    francis1291
    also thanks for the good jobs and stuff
  16. Feb 10, 2011 at 8:49 AM
    #56
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
  17. Feb 10, 2011 at 8:58 AM
    #57
    francis1291
    Thanks man. Does it even matter if I pit that last bolt in like the hard one to get to?
  18. Feb 10, 2011 at 9:07 AM
    #58
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Nope! Dont even worry about putting that one back
  19. Feb 10, 2011 at 9:29 AM
    #59
    Nightstr
    Felipe
    Sacramento CA
    05 prerunner sr5
  20. Feb 10, 2011 at 9:37 AM
    #60
    SmilingMark
    Mark
    Ogden, UT
    2010 Access Cab
    Do you guys just have really short arms or what? I didn't have that much trouble with that bolt. Only problem is that I undid the lower bolt when I first took them off.
