Blind Spot Adhesive Mirrors or Replacement Mirrors Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Sep 6, 2011.
  1. Sep 6, 2011 at 10:33 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    I have used many adhesive blind spot mirrors in the past, no problems. Now I can't find any place with good mirrors. The adhesive is too small resulting in mirrors that fall off. I've been to O'Reilly's, Walmart, Target, Autozone. This is ridiculous. It's just a friggin stick on mirror!
    I'm looking for a 3" round with good adhesive
    OR
    aftermarket mirror replacement with a built-in blind spot mirror and anti-glare surface/coating.
    Anyone?
  2. Sep 6, 2011 at 11:58 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I dont like the 3 inch
    takes up too much of the mirror.
    Napa??
  3. Sep 7, 2011 at 12:00 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i like the 2 inch spots. make sure you use some solvent to clean the mirrors surface before you apply them. ive never lost one
  4. Sep 7, 2011 at 5:58 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I used some from the dollar store. Alcohol preclean is key. I only had problems with them falling off when I hit them with the snow brush, but only when it's near or below 0F.
  5. Sep 7, 2011 at 6:11 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I agree about the 2". I have one on drivers side. Been on 2 years now and I don't think I even cleaned the mirror first.
  6. Sep 7, 2011 at 6:39 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might try removing the original adhesive and using some 3m double sided tape. Wrap some of that sh-tuff around your tires and you'll be able to climb a tree :)
