Blind Spot Monitor Not Available - 2016 TRD Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by agoode26, Jan 4, 2018.
  1. Jan 4, 2018 at 1:11 PM
    agoode26
    agoode26 [OP] New Member
    AG
    2016 TRD Sport 4x4 - Quicksand
    5100 Bilstein Lift, rear add a leaf, 275/70/17 BFGoodrich K02s, 17" Fuel Beast Wheels
    I have 2016 Tacoma TRD Sport, purchased in November 2015. Approx. 17,000 miles.
    Couple weeks back, my BSM Monitor beeped and a notification appeared reading "BSM System Not Available". I washed the truck, waited a couple weeks, turning the system on and off daily, in hopes it would start to function properly again. No dice.
    After maybe 3 weeks, I take it to my local dealership. They informed me the BSM System failure is due to the fact I had the suspension leveled, coupled with the addition of larger tires. Of course, because they concluded the issue is due to after market parts, it is not covered by the manufactures warranty, and is going to cost $399 to be recalibrated.... Three hundred and ninety-nine dollars...
    What I'm confused about, and what I told the dealership, is that I leveled the suspension, and added the aftermarket tires and wheels, almost two full years ago, in January 2016. The BSM System had been working fine until just recently. I'm not confident in their conclusion, and I declined the repair. I plan on calling a couple other dealerships in the area.
    Any guidance here would be appreciated.
  2. Jan 4, 2018 at 1:13 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I thought the lift height issue only affected 2018's with their new lane change radar nanny state bullshit.
    TimC and agoode26[OP] like this.
  3. Jan 4, 2018 at 1:15 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    I would ask them to specifically detail why they believe the lift caused the issue in writing. Tell them you need that for the case you're opening with corporate. And yes, find another dealer...
    SandyTaco4x4, Captqc and agoode26[OP] like this.
  4. Jan 4, 2018 at 1:16 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
  5. Jan 4, 2018 at 1:21 PM
    ksj
    Pacific NW
    265/70-17 KO2
    02/27/17 Electrical and Air Conditioning NHTSA ID: 10093114
    TSB ID: T-SB-0010-16
    Tsb: some 2016 model year tacoma vehicles equipped with blind spot monitor may exhibit a blind spot monitor warning message with diagnostic trouble code (dtc) c1ab2 short to gnd in outer mirror indicator (master) or c1ab3 short to gnd in ou
    CanadaToy and agoode26[OP] like this.
  6. Jan 4, 2018 at 2:21 PM
    agoode26
    AG
    Thanks for the suggestions! I referenced that TSB. They are checking back on that now and getting back to me.
    I called the dealership back and asked for the detail in writing. Though, after just speaking to the service rep again, what he said is that they aren't telling me the recalibration isn't covered by the warranty because the after market Lift/Tires "CAUSED" the BSM to become unavailable. They said they wouldn't be able to pinpoint the root cause of the failure. Instead, they are saying that the calibration is not covered because of the "EXISTENCE" of the after market parts on the vehicle.
    I pressed the service rep, questioning the logic of paying out-of-pocket for the repair of an OEM part that failed, because of the existence (not the cause) of aftermarket parts. And not only did they not cause the failure. The OEM part was working fine while coexisting for 2 years. The rep could only muster an unsatisfactory reply of "Yeah, I'm only relaying the information i received from the warranty department".
    We'll see what he says after he speaks with the Technician about the TSB mentioned above.
  7. Jan 4, 2018 at 2:34 PM
    ksj
    Pacific NW
    265/70-17 KO2
    Hmm, I would mention the Magnuson-Moss Act. What he said sounds like exactly why the act exists.
    AZJuice likes this.
  8. Jan 4, 2018 at 2:42 PM
    agoode26
    AG
    Oh wow, yeah you're right. I'm going to use that. Basically, it's unlawful for them to deny warranty coverage, unless the aftermarket parts CAUSED the defect. Awesome, man. Thanks!!
  9. Jan 4, 2018 at 5:58 PM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    Try disconnecting the battery for a few minutes. Worked for me.
    SandyTaco4x4 likes this.
  10. Feb 1, 2018 at 6:30 AM
    Plummsauce
    Plummsauce New Member
    2016 Tacoma TRD black
    I’m currently getting the same kind of pushback from my dealer regarding my after market electric starter that was installed by the dealer when I bought the truck. My BSMS started blinking without any vehicles around. It’s currently at the dealer they still haven’t found the cause but are telling me it may not be covered under warranty because of the starter - I’m in Canada I don’t think that act will help me here.
    New to the group any thoughts would be greatly appreciated
    Pella likes this.
  11. Feb 22, 2018 at 2:15 PM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Was there any progress?
  12. Feb 22, 2018 at 10:33 PM
    Plummsauce
    Yes They found it was a wire harness causing the issue and covered it under warranty without any issue thankfully
  13. Feb 23, 2018 at 7:43 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Try another dealer maybe and say nothing about tires & lift.
  14. Feb 23, 2018 at 7:54 AM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    sounds like you learned that particular dealership is busying themselves looking for reasons NOT to spend time looking for the real cause. My closest dealership is exactly the same way.
    The hammer likes this.
  15. Aug 26, 2018 at 4:59 PM
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Just got this exact same issue on my Taco, same amount of miles on my truck too. Any one else? Hoping the above TSB helps me out
  16. Oct 19, 2018 at 11:42 AM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I'm going through this BS right now.... I gave the dealer the TSB and he said they already have my entire dash apart and are talking with the Toyota engineers who write the TSB's.... Sounds like total BS to me.
  17. Oct 19, 2018 at 12:55 PM
    orangeracer
    Mine just ended up needing to be recalibrated, and it was covered under warranty.
  18. Oct 19, 2018 at 5:45 PM
    Hank_Mille
    PNW
    2016 Tacoma Limited
    After spending the entire day ripping apart the dash, they finally determined that the rear sensors are bad and 'perhaps' the actual CPU. Claiming a total price of over $4K and several more days to obtain parts, etc. Supposedly Toyota is paying for it as I have been mentioning/documenting the issue for the last 25,000 miles...
    They gave me a loaner car - an Avalon. Not bad, but I can't use it to tow my toy hauler to the track for the last weekend of the season... FML
  19. Oct 25, 2018 at 12:22 PM
    Hank_Mille
    PNW
    2016 Tacoma Limited
    Update - Dealer replaced the right side sensor and wire harness $1,775 in parts & labor covered by Toyota.... Total price to me was $0.
  20. Oct 25, 2018 at 12:32 PM
    orangeracer
    The BSM is one of the reasons I will go back and get the extended warranty before my bumper to bumper warranty expires. All this new tech costs so much to fix.
    Boghog1 and uploadadventure like this.
