blind spot not working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by afdtrdpro, May 21, 2018.
  1. May 21, 2018 at 8:05 PM
    afdtrdpro
    afdtrdpro [OP] Member
    chris
    17 trd pro
    Hi guys, new to the forum. I think this question might have been answered but this could be a different question so ill give it a shot. I have a 17' pro and the BSM had stopped working a few weeks after I got it last November. I kind of blew it off because it didn't really bothered me and I use my mirrors when I lane change. That being said I went to the dealer for other maintenance and thought I might as well throw that on the list. When I picked the truck back up I was told they ran a diagnosis and the system works fine but that dirt and debris can cause a problem. That being said the system still said unavailable when I left (figured I would do a deep clean). That was about a two months ago and it still remains unavailable. Is this a problem that is on me and really is just a cleaning issue? Or is the dealership just being lazy and not fixing it? Kind of feel like they should have at least cleaned it and had it working when I left. Thanks
  2. May 21, 2018 at 8:21 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Dealership lazy as hell. Mine wasn't working and was fixed under warrenty. Mine said BSM unavailable on the dash. They had to replace the the whole unit cuz it wasn't registering.
    over60 likes this.
  3. May 21, 2018 at 8:27 PM
    afdtrdpro
    chris
    17 trd pro
    Alright thanks, I figured that.
  4. May 21, 2018 at 8:31 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Did you take the lazy turds suggestion and wash the sensors? Happened to me in another car.
  5. May 21, 2018 at 8:31 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    ditch it for a 1st gen! Not as much fancy sensors, thingies and electronics that can fail!
    haha joking
    Yep, sounds like dealer didn't bother and was too lazy to do shit about it...
    afdtrdpro[OP] likes this.
  6. May 21, 2018 at 8:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Usually when I get a complaint of BSM the light won't turn on and there will be a code stored in the master or slave system. Sadly these codes are propriatary and can't be viewed without a tech stream.
    Does it work some of the time? If it doesn't work at all, it's a legitimate complaint and should be resolved under warranty.
    I usually have to re-calibrate them and have no further issues.
  7. May 21, 2018 at 8:36 PM
    afdtrdpro
    chris
    17 trd pro
    I was lazy so I did not, was hoping they would since it was "a part malfunction"
  8. May 21, 2018 at 8:37 PM
    afdtrdpro
    chris
    17 trd pro
    When I first got it, it worked for a week, stopped, then worked for a few days, and then hasn't worked since.
  9. May 21, 2018 at 8:38 PM
    Bishop84
    Re-book the appointment and address the service manager, this is unacceptable. Either it works or it doesn't, we can't let trucks drive away telling them its dirt causing the problem.
  10. May 21, 2018 at 8:38 PM
    ryfox0276
    Montana
    2013 RC 4x4
    This really doesn’t seem like it would be a dirty sensor issue, unless you immediately took it out in some mud or something.
    But I’d check off that box just to make sure.
    And welcome to tacomaworld.
  11. May 21, 2018 at 8:40 PM
    afdtrdpro
    chris
    17 trd pro
    okay and thanks
  12. May 21, 2018 at 9:38 PM
    sandman9
    sandman9 New Member
    2017 Tacoma Sport DCSB manual
    Cooper AT/w
    I just went through this with my 2016! Mine quit randomly while driving on a snowy road to work a few months back. I tried it periodically but I had to shut it off because i got the beep and message on the dash saying the BSM are unavailable. Left if for a couple months not working.. Until it took a trip to the dealer for other work, I mentioned that to the service guys.
    Their response was to say I had damage to my rear bumper (I did not) and that their diagnostic showed it was out of alignment 5 degrees and their tolerance was only 3. So they claimed it was my fault and not a warranty issue, AND even said I should take it to another dealer to hear the same thing. Even after getting the service manager they claimed that my option to fix it was to take it to a body shop for an alignment (theirs was about $200) then to get it recalibrated ($190). Needless to say I was not happy with a 1 year old truck starting to lose 'safety' options, and being told it was my fault, and it would cost $400 bucks.
    A couple weeks after I picked it up i washed it and stepped on the bumper to wipe down the back windows. Whether my stepping up aligned it enough, or the wash cleaned out debris from the sensor, I dont know what it was, but they work now without an issue.
    My advice is step on both sides of the bumper step and wash it, my Toyota dealer was useless and made up a story to not take accountability and had no desire to help. Dinks!
  13. May 21, 2018 at 9:55 PM
    Flanny
    Flanny Active Member
    Upstate NY
    2016 DCSB TRD Offroad
    Mine stopped working, I mentioned it when I took it in for the 10k service and they said the sensors needed to be realigned, they fixed it under warranty
  14. May 29, 2018 at 9:21 PM
    heatherisbetter
    heatherisbetter New Member
    SLC, UT
    2017 "Blazing Blue" TRD sport
    So I just went to the dealership for the same issue. They accused me of being in a wreck, which is a negative. Then they said they wouldn't fix it today and that I had to reschedule to have the whole system rerouted.. :confused: going in tomorrow and I am printing that info above!
