Blinker Bulb Burnout
Discussion in '2nd Gen. Tacomas (2005-2015)' started by friendlyphil, Apr 4, 2024.
  1. Apr 4, 2024 at 5:34 AM
    friendlyphil
    friendlyphil [OP] Member
    2015 Prerunner Dbl Cab. Barcelona Red. TRD
    I have burned out 4 bulbs from my front, driver's side, turn blinker in the past 3 or 4 months. They last a few weeks, then burn out. What should I check? 2015 Taco.
  2. Apr 4, 2024 at 6:18 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Sounds like your blinker fluid may be low.
    But seriously, are you using OEM bulbs or just any off the shelf auto parts store brand? I'd double check to make sure that you're getting the correct bulb for the vehicle. You can check the fuse panel for a damaged fuse that may not be popped but stuck closed making the bulb filament the next weakest point. After that, I would check your connections at the light housings for evidence of arcing or burning.
    -J
    Island Cruiser and six5crèéd like this.
  3. Apr 4, 2024 at 6:43 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  4. Apr 4, 2024 at 6:46 AM
    caribe makaira
    Caribbean, Puerto Rico
    I'd say it's an oxidized bulb contact(s) on vehicle harness...post a pic of it.
    wilcam47 likes this.
  5. Apr 4, 2024 at 6:49 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I switched to synthetic blend, no more problems :yay:
  6. Apr 4, 2024 at 6:57 AM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    China made bulbs are notorious for having un-supported filaments. My wife driving a rural mail route (some dirt and not so smooth roads) had a magnetic blinking light on car and kept burning out bulbs every few weeks. I switched to US made bulbs and no more problems.
    Taco 422 likes this.
  7. Apr 4, 2024 at 2:15 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Are you wearing latex gloves when you replace the bulbs? Don’t know if you need to for your particular bulbs but for most bulbs you should. The salts and oils on your fingers will damage most bulbs causing excess heat build up where you touched it and bulb failure. Change them and wear latex gloves, that may solve the problem.
    Island Cruiser and vssman like this.
  8. Apr 4, 2024 at 4:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you are using the correct bulbs, then it sounds like a resistance issue.
    Like stated above.
  9. Apr 4, 2024 at 5:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    Look at the bulb socket as previously suggested. Also if there’s a connector, unplug it and look at that too. A little dielectric grease might help.
    I have to change the older style bulbs with the single and double tits on a regular basis. Very often I’ll find the bulb socket black with carbon. So I keep a nail file together with my bulbs. It’s not a normal file, it’s more like a sharpening stone, works perfectly for scraping the carbon off. With the new style bulbs, you can’t really get in there to scrub it off. Doing so would probably make the bulb not make contact.
    Looks similar to this.
    https://www.amazon.com/Rolabling-Bu...sprefix=finger+nail+file+stone,aps,242&sr=8-7
  10. Apr 4, 2024 at 5:37 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    My truck is partial to the 3157NAK bulbs - for whatever reason...... The Krypton gas "K" is necessary to get the cooler running bulb. And for whatever reason the 4157 version is a really pale yellow instead of amber. Don't have any idea what that's about.
  11. May 18, 2025 at 10:18 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Were are you all finding 4157nak in stock?
