Blinker issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jeffrozsa, Aug 30, 2020.
  1. Aug 30, 2020 at 2:23 PM
    Jeffrozsa
    Jeffrozsa [OP] Member
    Hey guys, new to the forum. This place is badass! Anyways I just got a 2017 sr5 and my drivers side front blinker doesn’t work when I have my head lights on. I swapped the bulb from the other side and it does the same thing so I don’t think it’s a bad bulb. Other than the ground that’s right next to the battery, is there another one I can check? Fuses look good too...
  2. Aug 30, 2020 at 2:30 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Turn on the turn signal and check the power wire to the socket to see if it’s getting power.
  3. Aug 30, 2020 at 2:36 PM
    Tacomike18
    J
    If the power wire is getting power, possibly bad socket/contact. If the power wire is not getting power, locate the fuse or relay.
  4. Aug 30, 2020 at 3:21 PM
    Jeffrozsa
    So it’s getting power, I swapped the removable socket piece from the other side and it’s still having the same issue, maybe it’s the hard wired socket piece. Seems weird that it would be getting power though and it’s the bad socket. I checked the fuse under the steering wheel but is there a relay too? If so do you know where it’s located?
  5. Aug 30, 2020 at 3:26 PM
    Tacomike18
    J
    On your 17 sr5, it’s the headlight assembly with the amber light bulb that’s also the drl when the truck is in gear?
  6. Aug 30, 2020 at 3:26 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Do your hazard lights flash on all 4 corners?
    Turn signals go through hazard light switch.
    Skydvrr likes this.
  7. Aug 30, 2020 at 3:35 PM
    Jeffrozsa
    Yes it is
  8. Aug 30, 2020 at 3:36 PM
    Jeffrozsa
    Same issue w hazards. Flash fine w the headlights off but front driver won’t flash when headlights are on
  9. Aug 30, 2020 at 3:38 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Low on fluid?
    TheCochese and Hank Heel like this.
  10. Aug 30, 2020 at 3:39 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Has it been hit in that corner? CarFax show anything? Can you see any repair work in the engine compartment?
  11. Aug 30, 2020 at 3:40 PM
    Jeffrozsa
    ha damn! That’s it! Blinker fluid reservoir was bone dry
    tirediron[QUOTED] likes this.
  12. Aug 30, 2020 at 3:40 PM
    Tacomike18
    J
    See if the drl turns on, running out of ideas.
  13. Aug 30, 2020 at 3:45 PM
    Jeffrozsa
    nope drl lights don’t come on
  14. Aug 30, 2020 at 3:47 PM
    Tacomike18
    J
    Check the drl fuse. In engine fuse box.
  15. Aug 30, 2020 at 3:49 PM
    Jeffrozsa
    Sorry didn’t realize they wouldn’t come on if my handbrake was on, they do come on but the drivers side seems dimmer
  16. Aug 30, 2020 at 3:53 PM
    Jeffrozsa
    drl fuse was missing so I replaced it, but it didn’t fix the problem
  17. Aug 30, 2020 at 3:56 PM
    Tacomike18
    J
    The drl light bulb in front is double filament. When head lights aren’t on, it’s brighter. When head lights on, it dims. With head lights on, you said one side is brighter. Possible short.
  18. Aug 30, 2020 at 4:04 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Interesting.
    I would look at the headlight/turn signal stalk. There’s a lot of contacts in that sumbitch. No spills or rain through the window incidents?
