Blinker issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shakemlemming65, Feb 19, 2025.
  1. Feb 19, 2025 at 2:32 PM
    Shakemlemming65
    Shakemlemming65 [OP] New Member
    Alexander
    2008 sliver Tacoma SR5
    Tacoma left Blinker stays on solid green non flashing when I hit the breaks or turn on my lights
    I am unsure if it is a short or wiring issue but the door shocks me as well after longer drives.
    Any help is appreciated on where to look. And how.
    Thanks
  2. Feb 19, 2025 at 2:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Door shock may be static. Are you in a cold low humidity area when this happens?
    On the lights, are they all OE style or have modifications been made? Like LEDs?
    TnShooter likes this.
  3. Feb 19, 2025 at 2:50 PM
    Shakemlemming65
    Alexander
    The lights are led from Amazon I’ve had them in for 6 months now. And yea it is cold in New England right now might be that static.
  4. Feb 19, 2025 at 3:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    Put the old bulbs back in and see what happens.
  5. Feb 19, 2025 at 3:17 PM
    Shakemlemming65
    Alexander
    Ok, I lost the old set I had, in theory could I just in plug the connectors and see how the blinker responds.
  6. Feb 19, 2025 at 4:49 PM
    Waasheem
    Waasheem
    2007 xrunner
    I get door shock occasionally. I think it’s seat to pants friction when sliding out. Try this, open door, reach left hand back and touch something metal, then slide out. Your hand grounds to metal, so any static created is immediately grounded.
  7. Feb 19, 2025 at 5:54 PM
    Pigpen
    Dan
    Northwest Montana
    I had the same experience shortly after replacing the reverse bulbs. Turns out I had pulled on the main tail light plug during that process. Simply unplugging it and reconnecting it solved the issue.
