blinker not working what should i do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MROBERTS, Feb 13, 2011.
  1. Feb 13, 2011 at 4:49 PM
    MROBERTS
    MROBERTS [OP] Active Member
    Stevenson AL
    06 PreRunner SR5
    10000k hids, horn relcation, and more
    my passenger side front blinker wont blink and the back flashes super fast i changed the bulb in the front to a brand new one and it still wont work i checked all the fuses and none were blown the blinker housing is not getting any juice to it what could be my problem?
  2. Feb 13, 2011 at 4:51 PM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    check the pigtail (plug) it self or wires going to it. or you could check for power going to the pigtail
  3. Feb 13, 2011 at 4:52 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    i did and its not getting anything could i have a short somewhere or something?
  4. Feb 13, 2011 at 5:06 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    do you have ground at least? your just gona have to start tracing down the wires.
  5. Feb 13, 2011 at 5:10 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    could it be behind the dash somewhere?
  6. Feb 13, 2011 at 5:17 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Check blinker fluid level.
  7. Feb 13, 2011 at 5:21 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    you should find and print yourself a wiring diagram for the turn signals. just trace the wire back because your rear blinkers working meaning everything should be fine but the wire going to the front blinker.
  8. Feb 13, 2011 at 5:40 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    it done it when i installed my hids and it just stopped why does the rear blinker flash fast and the dash light flashes super fast why is it doing this?
  9. Feb 13, 2011 at 5:48 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    thats usually a sign of one of the bulbs no working
  10. Feb 13, 2011 at 5:50 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    are you sure you got the correct bulb for the one you changed?
    that or take it out and re-insert it, may not be making a good contact.
  11. Feb 13, 2011 at 6:07 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    :stirthepot:
  12. Feb 13, 2011 at 6:11 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    yea i change it and took it out and put it back in like fifty times
  13. Feb 13, 2011 at 6:16 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    I've had a similar problem once in the past on another vechicle. The problem turned out to be the bulb that was blinking faster than normal, it had a short in it. Try swapping the bulbs to the other side to eliminate them as the cause.
  14. Feb 13, 2011 at 6:19 PM
    skistoy
    Western New York
    that or you may have to back tace your hid install
    you may have somehow caused this new problem
  15. Feb 13, 2011 at 6:19 PM
    skistoy
    Western New York
    great idea, elliminate all you can as causes
  16. Feb 13, 2011 at 6:27 PM
    MROBERTS
    Stevenson AL
    06 PreRunner SR5
    but my hids do not have anything to do with my blinkers the run on factory harness and different grounds and different power source
  17. Feb 13, 2011 at 10:31 PM
    skistoy
    Western New York
    You mentioned it happened after you installed the hid.??
    you may have lost a ground, pulled a wire, nicked a wire, etc.
    the point being the blinker worked prior to hid, so something may have happened.
    may have to get a multi-meter and check grounds and for voltage
  18. Feb 13, 2011 at 11:46 PM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    just change it to a LED bulb like me :)
  19. Feb 14, 2011 at 7:44 AM
    joleger
    joleger Well-Known Member
    Saint John, NB
    2008 Access Cab 4x4 TRD Sport
    ROFL
  20. Feb 14, 2011 at 9:27 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Trade it in on a new truck.
