Blinker problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by DANBROWN, Nov 25, 2008.
  1. Nov 25, 2008 at 6:55 AM
    DANBROWN
    DANBROWN [OP] Member
    99 TACOMA EX-CAB 4X4 V6
    K&N FIPK KIT, WHEELS TIRES, HELIX POWER TOWER
    ok another problem I need help with. I have 99 tacoma and noticed my blinker light on the dash when I turn left was blinking really fast, my rear blinker is also blinking very fast but the front blinker is dead. I replaced the front bulb and it looked burned out, tried two differant ones but still not working and the dash and rear blinker still blinking at about three times the normal speed. when I turn on the right blinker it is at normal speed and front and rear normal.. thanks in advance guys...Dan
  2. Nov 25, 2008 at 7:39 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Ok have you the fluid? My old truck ran out of it!
    LMAO
    yo want to check fuses and be sure they are the right ones and not burned out. Also could be wrong bulbs, just some ideas.
  3. Nov 25, 2008 at 8:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take a bulb out of the RIGHT side front blinker (one that you know is working) and put it in the left side and TEST. If everything is good when you use the left signal - then you probably been putting the wrong type of bulbs in. If its still blinking fast - then there could be something wrong with the socket (the bulb plugs into) or the connections. I would unplug the wiring from the socket, inspect, clean if possible and plug it back in and test again. If your'e still having problems.... If possible - swap sockets from left to right and test.
    Weston_lee likes this.
  4. Nov 26, 2008 at 5:17 AM
    JVTACOMA
    JVTACOMA Well-Known Member
    Do you happen to have wiring for trailer lights. I've found this is often the root of some of those problems.
  5. Apr 7, 2011 at 11:13 AM
    SmokeyDP
    SmokeyDP Well-Known Member
    Somerville, NJ
    03 Tacoma
    Did you ever figure out what the cause of this is? I have the same thing going on in my 2003 and its only the front left that isn't working. The bulb lights when I turn on my running lights and it only has 2 wires going to it. When I turn on the blinker it just blinks fast.
  6. Apr 7, 2011 at 2:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Looks like you are no longer stock. Did you put the ARB bumper on? Since the stock blinker is in the bumper, some sort of rearrangement had to have occurred.
    Which light are you referring to here? Is it the one next to the headlight? Or is it down in your ARB bumper?
    A fast blinker is usually an indication of a wiring problem somewhere in the complete circuit which could include all the light bulbs on that side of the truck. Is the rear blinker on that side also blinking too fast?
    What works and doesn't work when you turn on the 4-way emergency blinkers?
  7. Apr 7, 2011 at 6:40 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    It's the light next to the headlight.
    If I turn on the running lights all 4 corners light as they are supposed to. If I turn on the left blinker, the front left stays solid and the left rear blinks fast.
    After 2 hours of messing around I dropped it off down the street and couldn't be hassled with it.
  8. Apr 7, 2011 at 8:54 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you change the Marker lights (the light next to the headlights) yourself? Stock they are not the blinkers. If they are you blinkers now, someone has rewired them to make them the blinkers.
    There are two ways to do the conversion. If the marker lights on your truck act as blinkers and act as running lights, the bulb type was changed by modifying the bulb socket and the wiring. If thats the case, the bulbs in there have two filiments and one of the filiments is burnt out.
    Did you take the marker housing off and pull the socket out and look at the bulb? Is it an 1157 bulb?
  9. Apr 8, 2011 at 6:08 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I'm pretty sure you are off on this. The marker lights have an OEM part number on them, and all OEM wiring going to them. They are the only lights up front that blink on my 03 and my 97. The lower ones do not blink. It's always the lights on the corner of the car that blink so that they are visible from the front and the sides.
    If it's not the orange corner light that blinks, then what mythical light assembly is it supposed to be?
  10. Apr 8, 2011 at 8:14 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    The "mythical light assembly" that blinks are circled in red for ya. No those are not fog lights. Those are the stock turn signals unless someone did the fog light mod on your truck.
  11. Apr 8, 2011 at 8:46 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
  12. Apr 8, 2011 at 8:49 AM
    kmok
    Kyle
    Columbus, Ohio
    Did you notice how the video was titled Blinker MOD :facepalm:
    That is not the how the stock blinkers work...
  13. Apr 8, 2011 at 9:07 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Well I guess I am wrong on this one. I found the DIY's for the blinker mods too.
    Both my Tacoma's had the orange lights blinking too. Yesterday I was looking under the bumper and under the hood and everything looked stock. There is only one bulb in the assembly too.
    Mechanic called up and said there was a short in the lower blinker. Now that it's fixed both are blinking like they should be.
  14. Aug 9, 2017 at 1:40 PM
    boe
    boe New Member
    This is the second time in about 10 years where my turn signal problem was because my "U-Haul" 3 to two wire converter for a trailer went bad. Snipped it off and now all is well.
