Blinker to "foglight" retrofit
Discussion in '1st Gen. Tacomas (1995-2004)' started by calebdnehus, Jul 9, 2013.
  1. Jul 10, 2013 at 7:59 AM
    calebdnehus
    calebdnehus [OP] Well-Known Member
    Caleb
    Arkansas
    '98 Prerunner V6--2004 Tacoma facelift
    K&N cold air intake FPIK, FlowMaster 40 series muffler, Euro Diamond clear headlights, 2003 tacoma tailights, bixenon HID headlights, 4 inch lift, pioneer headunit w/kicker door speakers(amped w/Rockford four channel), 2004 facelift, led dash light mod, painted needles, black auto shifter, leather steering wheel, ultra gauge. Plenty to come... Still
    That was the best idea I had at that point in the night, haha. What do you think I could use to keep the heat off the plastic? Maybe a smaller bulb might burn at a lower temperature. Idk
  2. Jul 10, 2013 at 12:00 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I've seen some pretty small projector fogs in an old Audi headlight, maybe try and use something like that in your blinker. That might help with heating as they have their own housing. They were about the size of a half dollar, but couldn't tell you the length and if they would fit. I always use Lexus fogs as they come with a mounting bracket for cheap at the junk yards. Make my own wiring harness with fuse and relay or use kits I find in other cars. Plus they are yellow projectors and that's what I like. Just mount them where ever.
  3. Jul 10, 2013 at 12:04 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    the only way you're going to keep heat off is a metal sheild. just buy a sheet or two from home depot and cut to fit. though it's still going to get really hot in there. maybe you should look into using LED products. that'd be much easier to control the heat
  4. Jul 10, 2013 at 3:48 PM
    calebdnehus
    Caleb
    Arkansas
    Didn't even think of this! I know LEDS run much cooler than normal halogen bulbs. I may have to go to a different bulb that is offered in LED and use that.
    Could also do the sheet metal thing along with projector idea. I'll have to play around with it and see what I can come up with. I just bought some HB2 plugs though so I will probably stick with that bulb. I will report back with my results and finish the write up. No promises on length though. Haha
  5. Jul 10, 2013 at 7:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  6. Jul 10, 2013 at 8:09 PM
    calebdnehus
    Caleb
    Arkansas
  7. Jul 11, 2013 at 3:47 PM
    calebdnehus
    Caleb
    Arkansas
  8. Jul 11, 2013 at 8:45 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
  9. Jul 12, 2013 at 12:36 AM
    calebdnehus
    Caleb
    Arkansas
    You're awesome man!!! Rock on!
  10. Jul 12, 2013 at 6:07 AM
    nzbrock
    Noah
    San Marcos, TX
    Your welcome, I always check Amazon for everything. It usually ends up being cheaper since I have prime.
  11. Jul 12, 2013 at 9:58 AM
    calebdnehus
    Caleb
    Arkansas
    I need to start doing that so I can save a little money on my stuff here and there
  12. Jul 12, 2013 at 10:07 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    As there is no way to aim the light, is there not a distinct possibility of blinding other drivers?
    Fog lights are mounted low with a distinct cut off to help limit glare. There are really more of an un-aimed accessory light. Probably pretty good for off road use.
  13. Jul 12, 2013 at 12:40 PM
    calebdnehus
    Caleb
    Arkansas
    It's possible. I will have to get it all set up and get out in front of my truck to see how bad the glare would be and think of possible adjustments to make. Fitting a projector into the housing was mentioned earlier and they may be what I do once I get enough time to sit down with my project again
  14. Jul 17, 2013 at 10:03 PM
    calebdnehus
    Caleb
    Arkansas
    Thermotape will arrive July 23rd
  15. Jul 22, 2013 at 3:31 PM
    #35
    calebdnehus
    Caleb
    Arkansas
    Got my tape today, working on covering the inside of the housing. Will post pictures when I'm done
  16. Jul 22, 2013 at 9:53 PM
    #36
    calebdnehus
    Caleb
    Arkansas
    I tested one light today and it worked well. The halogen bulb creates a lot of heat though, I will probably get some LED bulbs to replace them. Better safe than sorry
  17. Aug 5, 2013 at 10:59 PM
    #37
    calebdnehus
    Caleb
    Arkansas
    Still waiting LED bulbs to come in. Damn shipping
  18. Aug 7, 2013 at 9:44 PM
    #38
    calebdnehus
    Caleb
    Arkansas
    Finalized covering the other housing with thermo tape. Will start wiring tomorrow or the next day. Will keep posting for those interested, if there is any. Haha
  19. Aug 9, 2013 at 1:46 PM
    #39
    calebdnehus
    Caleb
    Arkansas
    I got the LED HB2 bulbs today. I tried to test them out and they wouldn't work?? Anyone have any idea why this would be?
  20. Aug 9, 2013 at 3:36 PM
    #40
    trussell456
    trussell456 Well-Known Member
    Tyler
    Maine
    03 TRD V6 5-Speed
    Bilstein 5100's / Eibach's / AAL / All Pro Front Bumper / Skids / Billet Grill / 33x12.5x15 Duratracs / Dick Cepek DC-2's / TRS Retrofit / 20" Light Bar / 6" HID Fogs / Wet Okoles / WeatherGuard Tool Box
    LED's are usually polarity sensitive. whats your socket look like? any way to reverse the bulb?
