Blinkers and hazards not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by cructio76, Mar 26, 2025.
  1. Mar 26, 2025 at 11:25 PM
    cructio76
    cructio76 [OP] New Member
    Hello, my blinkers and hazards are not working in my 97 Tacoma i checked fuses and they were fine.
  2. Mar 27, 2025 at 7:30 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
  3. Mar 27, 2025 at 7:45 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Did you check you Blinker fluid? Could be low, ya know.
  4. Mar 27, 2025 at 12:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'd pull the flasher button and see if you have power on the Red/Black wire.
    Then you need to back probe the Green wire with the connector plugged in. It should have power (12v) with the switch OFF. (not pressed in)
