Blinkers being weird
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Baseophobia, Jun 2, 2023.
  1. Jun 2, 2023 at 7:51 PM
    Baseophobia
    Baseophobia [OP] New Member
    Hayden
    2010 silver base model full cab tacoma
    keyless entry pioneer sound system
    My front indicators will not work after installing led bulbs in the rear I did replace the light control module with an lm449 and have alpha Rex headlights the rear indicators work but slightly faster than stock while the front does nothing also my left turn signal come on on the dash when I brake please help me
  2. Jun 2, 2023 at 8:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does your truck have DRL?
    The flasher is different between DRL and non DRL equipped trucks and to my knowledge nobody makes a LED compatible flasher for DRL equipped trucks.
    DRL Flasher has 12 pins, non DRL flasher has 8 pins.
    Too Stroked likes this.
  3. Jun 2, 2023 at 8:39 PM
    Baseophobia
    Hayden
    It looks like you are correct I’ll put the stock one back and try putting resistors in the tails
  4. Jun 2, 2023 at 8:40 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Blinker fluid is low
    szidls and Geeves77 like this.
