blinkers for off road bumper...
Discussion in '1st Gen. Tacomas (1995-2004)' started by brelandt, May 18, 2011.
  1. May 18, 2011 at 6:23 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I want to remove the black plastic half of my front bumper and I need ideals on what to do with the blinker?
    I read the mod on installing the blinker in the side marker lamp, but I really don't like this.
    I seen the blinkers for motorcycles on Amazon for $15 and of course the trailer lights at the auto store. Has anyone come out with a good blinker set up like one they pulled off of a Eagle Talon from the junkyard and something crazy like that?
  2. May 18, 2011 at 6:26 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
  3. May 18, 2011 at 6:34 PM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
  4. May 18, 2011 at 6:37 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I bought two led strips and ran them under the headlights.
  5. May 18, 2011 at 6:51 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Alot of people just re located the blinkers into the corner marker lights.
  6. May 18, 2011 at 6:54 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Got pics of that? I think I like that idea.
  7. May 18, 2011 at 7:47 PM
    Anthony250
    Anthony
    San Gabriel Ca
    yes. , just some $2 leds, and wired them up , DSCN2767_574397668396e2cbe09082d286216b7d3ef90563.jpg
  8. May 18, 2011 at 8:04 PM
    Enigmaaron
    PA
    1st gen superiority
    Nice, I might go that route when I get a bumper.
  9. May 18, 2011 at 8:12 PM
    brelandt
    Terry
    Dublin, CA
    Looks good Anthony! I wonder if they offer those in orange?
  10. May 18, 2011 at 8:20 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thanks guys, its really nice looking, just check ebay they make lots of colors. Im sure white and amber is legal.
  11. May 18, 2011 at 8:31 PM
    brelandt
    Terry
    Dublin, CA
    Did you have any issues in regards to the blinker being LED and the wiring for the truck set up for amber lights?
  12. May 18, 2011 at 8:44 PM
    Anthony250
    Anthony
    San Gabriel Ca
    What do you mean? Not really. All i did is hide the stock wiring with bulb and tapped into the positive and negative and connected and done.
  13. May 18, 2011 at 9:01 PM
    brelandt
    Terry
    Dublin, CA
  14. May 18, 2011 at 9:55 PM
    Anthony250
    Anthony
    San Gabriel Ca
    No problems at all. Just made sure i got 12v 24 Led strip and good to go.
  15. May 18, 2011 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Anthony left the original bulbs in the circuit so he doesn't have the "hyperblink" issue that happens when only LEDs are used.
    To avoid the hyperblink add a resistor for each side if you eliminate the original bulbs altogether. If you leave them in it is essentially the same result as when resistors are added to the circuit.
  16. May 18, 2011 at 10:04 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Exactly! Thank You
  17. May 18, 2011 at 10:07 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I just modded wiring and the corner marker lights with a dual element bulb to function as the turn signals on my GF's '03 when I put the bumper on.
    Not that hard really.
  18. May 18, 2011 at 10:31 PM
    brelandt
    Terry
    Dublin, CA
    Yeah, for some reason I'm just not crazy about it. don't know for sure why that is, just not too appealing. Then again I'm not very creative. Hoping to see some really cool tricks that I haven't thought of.
  19. May 18, 2011 at 10:37 PM
    RelentlessFab
    Eric
    I agree. At first I was reluctant, but after all said and done, I'm glad I did what I did. Looks as clean as from the factory on the outside of the truck since theres no aftermarket stuff just thrown on.
  20. May 18, 2011 at 10:38 PM
    brelandt
    Terry
    Dublin, CA
    Very good point!
