Blinkers into fog lights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by climber-420, Jan 7, 2009.
  1. Jan 7, 2009 at 9:42 PM
    climber-420
    climber-420 [OP] I love tight cracks
    PNW
    2004 Gold Ext Cab TRD 3.4L V6 Manual, 265/75/16 BFG KO2's(for sale)
    Grey Wire Mod, ARB Bumper, Warn M8000, Uniden 520 XL CB, rear diff breather mod, full time power to aux 12V outlets, Rago Fab ditch brackets
    I saw on a thread earlier that someone had made the cornering lights next to the headlights into blinkers and made the lights on the bottom of the bumper into fog lights. What do I have to do?
  2. Jan 7, 2009 at 11:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I don't think it would be a wise idea seeing how the lens wouldn't be able to take the heat from the fog bulbs and would melt the plastic lens.
  3. Jan 8, 2009 at 2:32 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Converting the corner units to include a relocated blinker is usually called the 'corner blinker mod' or the 'blinker relocation mod'. There are multiple variations on the exact procedure, usually differentiated by what else you end up doing with the original signals.
    The OEM signal lamps don't make good fog lamps or driving lamps, because their lenses aren't designed to provide either of the beam patterns those applications require. Unless you swap out the lamp units themselves, the most you'll have will be a couple of marker / parking lamps.
  4. Jan 8, 2009 at 2:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I converted my parking lights into blinkers & parking lights combo. That's as far as I went .... I had originally wanted to put fog lights where my blinkers were (on my 96) but I never completed the job.
    Here's what I did:
    http://www.lieblweb.com/tacoma/Mechanical/BlinkerConversion/blinker.html
    But yeah....you're better off totally removing the stock blinker lights completely (housing & all) and putting new fog lights into the bumper cutouts where the blinkers used to be.
