Blinkers not blinking
Discussion in 'Lighting' started by gm242, Jun 30, 2012.
  1. Jun 30, 2012 at 1:57 PM
    gm242
    gm242 [OP] Active Member
    Gabriel
    Miami
    2012 PreRunner
    LED Dome, LED Map Lights, Autopage w/remote start, Tints 15%+factory & 20%
    :help:
    I bought 3157 LEDs for the turn signals I installed them and parking light was working. Attempted to us the turn signal and nothing. Put back old bulb and parking light works just no turn signal.
    Checked fuses all good...I just disconnected the negative terminal.
    Any ideas :facepalm:
  2. Jun 30, 2012 at 2:03 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Read posts below--says you need an electronic flasher.
  3. Jun 30, 2012 at 2:29 PM
    gm242
    Gabriel
    Miami
    2012 PreRunner
    Just read about the fuses in the cab...going to try checking those.
  4. Jun 30, 2012 at 2:58 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    You check your blinker fluid?
  5. Jun 30, 2012 at 9:54 PM
    Hii
    Hii Well-Known Member
    ^^ what he said
    Your blinker fluid reservoir might be low
  6. Jul 1, 2012 at 9:15 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    He must have topped off the blinker fluid--
    Hope he got it fixed--electronic flasher--makes sense--l.e.d. will not draw enough current to heat up the standard flasher--Is this a correct assumption?
