Blinking AC light??? Please help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dee_bo, Jul 30, 2010.
  1. Jul 30, 2010 at 4:55 PM
    dee_bo
    dee_bo [OP] Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    Had my AC on and suddenly it started blinking and wasn't cooling. I clicked the button on/off and it has been working since. This is the second time it's happen...what does it mean. AC seems to be working well other than that...couldn't find this mentioned in the manual.
    Thanks in advance
  2. Jul 30, 2010 at 5:20 PM
    Jcook54
    Jcook54 Damn. Just damn.
    Stn.Mtn, GA
    10 PreRunner SR5 V6
    TBD
    I had a Camry that used to do that. However, it only happened when it was raining hard or kicking up standing water. I couldn't figure it out either. My only guess was (still is) that water got somewhere and caused the compressor to turn off for a minute. It was as if turning it off and on again acted as some sort of reset. Sometimes I would have to wait for a minute or two depending on how wet it was but it always seemed to work after a little while. The AC never had any issues beyond that and I traded it in for my Taco with 117,000 miles on it.
  3. Jul 30, 2010 at 5:23 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    mine is doing that and the compressor is locked
  4. Jul 30, 2010 at 5:28 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Common problem with Toyota. With an intermittent problem like that where it quits working then later on works okay, clear sign of a bad relay. I'd rather that be the problem with the AC than anything else since it's the easiest/cheapest to replace.
    desertrunner24 likes this.
  5. Jul 30, 2010 at 5:49 PM
    dee_bo
    DFW
    None yet
    If you could provide some insight on how to diagnose the problem or where the switch is located, I'd appreciate it. I thought maybe its cause my cabin filter is dirty or clogged....haven't messed with it ever.
  6. Jul 30, 2010 at 6:25 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    This has happened to me twice since I got my truck, last time was over a year ago. I just turned the temperature knob to hot then cold and it stopped blinking. I'm not too worried about it.
  7. Jul 30, 2010 at 8:12 PM
    05Moose
    Jim
    Well you don't want to just go replacing parts without truly diagnosing the problem. But that's just my guess without ever looking at it. Even the first steps in the diagnostics section for the A/C in the service manual are to check the fuses and relays. It's just that all the Toyota models seems to have problems with these relays sticking (and since it's intermittent, that's why this is my guess). The relay is in the engine bay fuse box.
  8. Jul 30, 2010 at 8:42 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have an alldatadiy subscription for my truck. The alldata manual says that the following conditions will cause the hvac controls to shut off the AC.
    Evap outlet air temp too low (must be a sensor somewhere)
    Compressor speed does not match engine speed (slipping comp clutch?)
    Refrigerant pressure too high or too low (overcharged? Leaking? bad pressure switch?)
    Engine speed is too low
    Rapid acceleration occurs (LOL)
    pats73 likes this.
  9. Jun 7, 2016 at 1:39 PM
    Markeb
    Markeb New Member
    it could be the speed sensor on the ac compresor
  10. Jun 7, 2016 at 3:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This is the issue. It could be several things:
    1. Belt slipping as when it gets wet.
    2. Defective AC Clutch.
    3. The AC Compressor is on the way out and seizing.
    Pray for it to be # 1 or # 2.
    pats73 likes this.
  11. Jun 7, 2016 at 3:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    On the face of the evap. Cycles the compressor somewhere around 36-38*F to prevent ice formation, which of course will stop air flow.
    pats73 and Jimmyh like this.
  12. Jul 1, 2017 at 5:51 AM
    pats73
    pats73 Member
    Rick
    06 taco trd quadcab longbed
    THANK YOU!!
  13. Jul 1, 2017 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    While the 'rapid' part is funny............
    I believe the ECU will cut the compressor when the TPS shows WOT.
    However, as soon as you come off WOT, the compressor should be released.
    So, if you have a flashing light just cruising around, this one isn't your issue. :D
  14. Jul 1, 2017 at 7:37 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I have this same issue, but it only happens when it been sitting in the hot sun all day. After pushing the button a few times it starts working normally. Haven't checked the relay though. My guess is the pressure is to high from the heat that it can't work. A/c blows super cold still after 11 years and never been serviced. If it were the compressor wouldn't squeal if it was going out?
  15. Jul 1, 2017 at 8:46 AM
    pats73
    pats73 Member
    Rick
    Sorry ima dumbass WOT? TPS ?(Pressure switch?)
    Thanks!
  16. Jul 1, 2017 at 8:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Throttle Position Sensor
    Wide Open Throttle (a condition of the TPS)
    MSN88longbed likes this.
  17. Jul 1, 2017 at 9:10 AM
    pats73
    pats73 Member
    Rick
    Duh! I KNEW THAT!
    Thanks bro! A little OVER analyses
  18. Jul 1, 2017 at 11:12 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd
  19. Jul 4, 2017 at 5:42 AM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
  20. Mar 9, 2020 at 5:48 PM
    Riverrokk
    Riverrokk New Member
    2012 Toyota Tacoma prerunner V6 2 wheel drive
    Rancho shocks and air lift leveling bags, brake controller, hitch
    Have blinking AC light but only when it rains,,,, turned off for while, then ON again and worked fine for a season. Next season cold air blowing on drivers side, HOT blowing on passenger's,,,,,any idea what cause is? OR how to repair without dismantling or replacing entire system????? TIA
