blinking CEL, engine stalls. Works fine a few minutes later
Discussion in '1st Gen. Tacomas (1995-2004)' started by pfoxgrover, Jul 4, 2018.
  1. Jul 6, 2018 at 12:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Making Progress at least now you have a place to start.
    Remember it is the complete circuit not just the sensor.
    Loose connection damaged wires
    Now my 2000 EWD says the ECM ground is under the the data link connector it might still be there
    As stated it should be 3 brown wires
    Happy hunting
  2. Jul 6, 2018 at 1:04 AM
    Bishop84
    Bishop84 Well-Known Member
    Blinking CEL on an older Toyota, I would look at the injectors and see if they are leaking, can usually spot it when the pressure it up and plugs are out with a small flash light.
  3. Jul 7, 2018 at 2:51 PM
    pfoxgrover
    pfoxgrover [OP] Well-Known Member
    So the local toyota dealer said they would diagnose it for $130. They had it all morning and said they couldn't get it to stall. I went over there to help them out. To make a long story short we were driving it with the laptop scanner hooked up and figured out by accident that touching the turn signal would make it stall. So like Wyoming09 suggested, sounds like a damaged wire. I left it there for them to finish trouble shooting and come up with a quote to fix it. I feel a lot better now with a clue what is wrong. Wondering if the steering shaft is chafing something. I will report back what they say.
  4. Jul 7, 2018 at 3:19 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Getting Closer
  5. Jul 7, 2018 at 7:41 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I doesn't seem like any wires related to the turn signal could interfere with the computer or engine, so I'll be curious to find out what the problem is.
    Do you have any sort of security system installed? Some of them require you to hold the headlight switch or something like that to start the car. I was thinking maybe a security system was erroneously shutting it down.
  6. Jul 8, 2018 at 1:33 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The turn signal switch might just have been a fluke but having it shutdown is better then not being able to see it happen at all.
