Blinking lights / no brake lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mbrown1782, Jan 28, 2018.
  1. Jan 28, 2018 at 8:53 AM
    mbrown1782
    mbrown1782 [OP] Member
    2012 Tacoma
    I am having a strange problem in2012 tacoma 4x4. I have no tail or brake light and when I turn on my left turn signal (only my left), all the lights on my dash / radio blink? Is this caused by a bad fuse some where?
  2. Jan 28, 2018 at 9:14 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Check your grounds under the rear of the truck for cleanliness and tightness. Check your battery connection as well
  3. Jan 28, 2018 at 9:51 AM
    mbrown1782
    2012 Tacoma
    Thanks desertrunner24 - is there just the 1 ground location by the drivers side rear wheel?
  4. Jan 28, 2018 at 10:06 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    No it should be under the bed by the drivers side tail light. The one buy the wheel is for emissions
  5. Jan 28, 2018 at 11:17 AM
    mbrown1782
    2012 Tacoma
    I took it off, cleaned (steel wooled) everything and put it back together - checked and changed the fuses too - no luck! Any other ideas I can try?
  6. Jan 28, 2018 at 11:23 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Are your battery terminals clean and tight? Check the relay under the hood swap with another one if swapping it fixes it then you know it a bad relay. Also check the flasher behind the interior fuse box
  7. Jan 28, 2018 at 11:23 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Have you just added any led bulbs anywhere. They can do weird crap.
  8. Jan 28, 2018 at 11:25 AM
    mbrown1782
    2012 Tacoma
    No,nothings been added. Just started happening all of the sudden!
  9. Jan 28, 2018 at 11:58 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Sorry was hoping for a quick fix for you. Seems I’d follow desertrunner24 s advice swapping relays. My 08 has non led tails.
    Not sure if a led could go bad and back feed?
    Or as was said a ground somewhere electrical gremlins suck.
  10. Jan 28, 2018 at 12:09 PM
    mbrown1782
    2012 Tacoma
    No such luck - I checked the terminals and fuses / relays with no help! Must be an electrical gremlin somewhere that I'l have to take in to get fixed...
  11. Jan 28, 2018 at 12:16 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    That sucks I’d be lost also.
    Sorry man good luck!
  12. Jan 28, 2018 at 12:36 PM
    mbrown1782
    2012 Tacoma
  13. Jan 28, 2018 at 3:53 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    You're going to have to start inspecting your entire wiring harness.
    My money is on rodents chewing through some wire somewhere.
  14. Jan 28, 2018 at 4:12 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I'd go after the tail /brake lights first - as it's a possibility fixing one thing will fit the other. Turn on your tail lights only they troubleshoot. Check the ground(s) to the frame IN the light sockets then check for 12v power IN the socket - one or both will be missing/bad. Trace back from there.
