Blistein @ 1.75 and alignment don't seem right
Discussion in 'Suspension' started by TwzteD, Dec 17, 2011.
  1. Dec 17, 2011 at 11:42 AM
    TwzteD
    TwzteD [OP] Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    i installed the 5100's last night i went to get it aligned today and I'm thinking i brought it to the wrong place! the numbers are pretty off id say here what they gave me after they aligned it... the right camber is way off and they told me that there is no adjustment for camber according to their machine..... am i right or am i wrong please let me know you opinions. and yes that is after the alignment because i told him i wanted a printout of the specs and he didn't print the before . well zoo he says.. maby i should have brought it to the dealer!
  2. Dec 17, 2011 at 11:49 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Are those the before measurements or the after?
  3. Dec 17, 2011 at 11:51 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  4. Dec 17, 2011 at 11:52 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You will probably get the same results from the dealer like myself and others have. Take it to a reputable alignment shop and when they do it right, take the printout to the original shop and demand your money back.
  5. Dec 17, 2011 at 11:52 AM
    TwzteD
    Kyle
    St Lucie Fl
    those are after measurements!
  6. Dec 17, 2011 at 11:53 AM
    TwzteD
    Kyle
    St Lucie Fl
    what are ideally the "within specs measurements" ill go else wear too bad i can't get my money back but I'm gonna try
  7. Dec 17, 2011 at 11:54 AM
    ktmrider
    Junk
    Yeah your camber is off it should be 0 and your caster is too low as well.
  8. Dec 17, 2011 at 11:55 AM
    ajohnson
    Andy
    Charlotte, NC
    Yea you probably won't get your money back, but it would be nice to show them that they don't know what they are doing.
  9. Dec 17, 2011 at 11:58 AM
    TwzteD
    Kyle
    St Lucie Fl
    whats a good number for the caster?
  10. Dec 17, 2011 at 11:59 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    The camber adjustment is on the lower control arm mounting bolt. It's a cam type washer. It moves the contol arm in and out providing tilt to the wheel.
  11. Dec 17, 2011 at 12:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Caster should be above 2*, with Camber at .4* or so.
  12. Dec 17, 2011 at 12:01 PM
    ktmrider
    Junk
    camber 0
    toe 0
    caster 2.4-3.1 depending on tire size (stock size 2.4 and larger get higher specs)
  13. Dec 17, 2011 at 12:04 PM
    acdronin
    acdronin Well-Known Member
    Try looking for a shop that specializes in 4x4's or maybe track down a 4x4 parts shop and ask them for a referral, dealers and regular shops are usually no good at this kind of thing.
  14. Dec 17, 2011 at 12:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    His caster isnt that bad for having a lift, and stock UCA's, but his Camber is all out of wack....
  15. Dec 17, 2011 at 12:06 PM
    TwzteD
    Kyle
    St Lucie Fl
    im not going to damage anything driving it like this for a little wile am i? just tire wear issues?
  16. Dec 17, 2011 at 12:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may have a little wandering, and outside tire wear.
  17. Dec 17, 2011 at 12:09 PM
    acdronin
    keep both hands on the wheel, the words 'wandering' and 5000lbs of truck are not things i want to see in the same sentence!
  18. Dec 17, 2011 at 12:10 PM
    TwzteD
    Kyle
    St Lucie Fl
    is the rear specs good ? cause i don't even think he touched the back
  19. Dec 17, 2011 at 12:28 PM
    TwzteD
    Kyle
    St Lucie Fl
    i found another place and i told him the whole situation and he said he will work with me i wrote down all ur input so heres what i got
    CAMBER: around .4* way out of spec
    CASTER: AROUND 2.4* current is decent.
    Toe: 0* Current is decent
  20. Dec 17, 2011 at 1:15 PM
    ktmrider
    Junk
    the rear specs are not adjustable
