Blistein 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sysnxt, Jul 11, 2012.
  1. Jul 11, 2012 at 7:05 PM
    sysnxt
    sysnxt [OP] Member
    I just ordered the adjustable 5100s for the front, and fixed rear 5100s. I also decided to go with a 2inch AAL all from ToyTech. My 05 TRD has about 90,000 miles on it, so should I replace the coils also? I was planning on setting the front 5100s on 1.75 just because I dont want to have to have the potential for needing new UCAs. I was also going to get the new bushing and washer kit, figured I may as well change them out while im in there. Basically I just want to spend as little as possible, but make sure I get what I need... am I forgetting anything? Any thoughts would be greatly appreciated.
  2. Jul 11, 2012 at 7:35 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    if you don't plan on adding any heavy front armor bumper then your stock coils should be fine. they normally won't sag if any at the age. everything sounds like a good plan to me. don't forget to do an alignment after they're installed.
  3. Jul 11, 2012 at 8:02 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    ^ Agreed.
    Some people need the 3 degree axle shim kit when they put in the AAL, some don't. You'll know if you get the 60MPH+ vibes that you'll need the shims.
  4. Jul 11, 2012 at 8:33 PM
    sysnxt
    sysnxt [OP] Member
    Would it be a bad idea to just do the shim kit while i have everything apart?
  5. Jul 12, 2012 at 1:53 AM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    sub'd.
    good question.
