Blisten shocks worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwater, Feb 3, 2013.
  1. Feb 3, 2013 at 12:16 PM
    dwater
    dwater [OP] Member
    05 pre runner
    Ok so I recently purchased a taco I traded my non 4x4 for a 4x4 Tacoma which wasn't the off road edition. Now my buddy with an off road lifted his truck at 38k and he has the blisten shocks laying around. My question is, is it worth taking his shocks and installing it on my taco? Will I get a little bit of a lift? And will the ride quality be noticeable? He is selling them for 80$ by the way is this a worth it upgrade?
  2. Feb 3, 2013 at 12:18 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    It sounds like his billsteins are the factory billsteins from the TRD models.
    Basically you won't get any lift, but the springs are going to be progressive vs the linear coils you have now, giving ( from what I've read) a slightly softer ride on road
  3. Feb 3, 2013 at 12:19 PM
    Brandon###
    Brandon### Well-Known Member
    No, you will not get any sort of lift. Shocks do not "lift" the truck.
    Would you be able to tell a difference? Not sure because no one knows the condition/mileage of your current shocks or the ones your buddy has...
    If both sets were brand new, I wouldn't waste my time swapping them.
  4. Feb 3, 2013 at 3:16 PM
    dwater
    dwater [OP] Member
    05 pre runner
    Thanks yea his had about 38k and right now my taco has 19k so if its not going to make a difference I'm just going to keep my shocks thanks for the input guys
  5. Feb 3, 2013 at 3:19 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd take 'em if I were you.
  6. Feb 3, 2013 at 3:33 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I installed a used set of blistiens and could notice a good difference.
  7. Feb 3, 2013 at 4:00 PM
    dwater
    dwater [OP] Member
    05 pre runner
    Ok so is the install as easy as changing shocks on a Honda? Sorry if this sounds like a stupid wiestion
  8. Feb 3, 2013 at 4:04 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Not entirely true. If it is the adjustable Bilsteins then it would...
  9. Feb 3, 2013 at 4:51 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Yea the back super easy. Front you will need spring compressors
  10. Feb 3, 2013 at 6:52 PM
    dwater
    dwater [OP] Member
    05 pre runner
    Even if its the full shocks? Is there a write up on this?
  11. Feb 3, 2013 at 6:53 PM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I'm sure there is. If the coils are still on the front shocks than it will be a easy job. Just use search tab for instructions.
