Blitzpro Hawk 21S LED Light Bar Group Buy
Discussion in 'Group Buys' started by Trifenix, Aug 31, 2012.
Thread Status:
Not open for further replies.
  1. Nov 26, 2012 at 5:16 PM
    #641
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    u should be fine as long as it is fused. The relay just takes the load off of the switch so you wouldnt have all those amps on the switch. But if your not any were near ur max amp limit of the switch you should be fine. Just make sure there is a fuse. LOL i must say that a few times haha
  2. Nov 26, 2012 at 5:21 PM
    #642
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    That's what I figured. I actually just test fitted a 6 position fuse panel under the hood but couldn't find a good place for it to go. I would have three accessories on my positive battery terminal as if I add a light so I'm looking to clean it up a bit.
  3. Nov 26, 2012 at 5:33 PM
    #643
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    its even worst with relays, cause you need power to the relay and switch, so 2 positives for every aux light. then you got to find a place for the relay. Pain i tell you lol
  4. Nov 26, 2012 at 5:53 PM
    #644
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
  5. Nov 26, 2012 at 6:11 PM
    #645
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
  6. Nov 26, 2012 at 6:19 PM
    #646
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    always fuse if runnign a wire off the batery or some other power source.
  7. Nov 26, 2012 at 6:28 PM
    #647
    Hewitt
    Hewitt Active Member
    Tyler Hewitt
    Missouri / California
    07 FJ
    Icon Stage 1 3" lift, 1.5" Wheel spacers, DeMello Off-Road Baja style bumper, LED everything possible, Blitzpro LED amber dust light, TWO 21" Single Row Light bars, TWO 11" Double row LED Light Bars, M.O.L.L.E. Seat covers, K&N CAI, TRD Exhaust, Magnaflow muffler, BMC.
    Does anyone have an amazing write up for flawless wiring. I.E.: adding fuses, adding relays, etc.
    Thanks!
  8. Nov 26, 2012 at 6:29 PM
    #648
    Hewitt
    Tyler Hewitt
    07 FJ
    Also, really descriptive, pictures and other helpful items.
    Thanks again.
  9. Nov 26, 2012 at 6:31 PM
    #649
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fuse anything and everything.
    Should be. But I burned up most my wiring with two of the 6" bars for my mirror lights. I'd just get a relay..just me though
    Think they are 50w fogs. You'll be more then safe running the 21s off your stock harness
    Not true. You can route the ground through the switch on the relay. Safer amd effective. What I do
    X2
  10. Nov 26, 2012 at 6:31 PM
    #650
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ill have one that should help in a bit
  11. Nov 26, 2012 at 6:33 PM
    #651
    Hewitt
    Tyler Hewitt
    07 FJ
    Thanks buddy.
  12. Nov 26, 2012 at 6:34 PM
    #652
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    what do you mean by this? cant picture what your saying.
  13. Nov 26, 2012 at 6:36 PM
    #653
    Blackdawg
    Monte
    Wyoming/St. Louis
    By running power to both three of the posts then the switch run the ground to the post of the switch side if the relay. Makes for a cleaner install too
  14. Nov 26, 2012 at 6:39 PM
    #654
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Should i combine both wires from the fogs into the led(like strip left and right postive, then run those into the postive of the LED) or can i get away with just doing one side?
  15. Nov 26, 2012 at 6:40 PM
    #655
    Blackdawg
    Monte
    Wyoming/St. Louis
    I would assume just one..but can't hurt..
  16. Nov 26, 2012 at 6:41 PM
    #656
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Sorry, i dont understand what you mean.
    do you follow something like this? or are you using a 5 pin relay?
  17. Nov 26, 2012 at 6:47 PM
    #657
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sorta.
    I skip running power to the switch. Instead I just run power to 86 87 and 30. The. The switch goes on the 85 side with the ground. No power goes through the switch keeping it from melting. All the power stay over at the relay.
    Make sense?? I can get a photo of what I'm talking about.
  18. Nov 26, 2012 at 6:47 PM
    #658
    CayucosTacoma
    2004 Double Cab 4x4
    cool thanks!
  19. Nov 26, 2012 at 6:48 PM
    #659
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    now i gotcha. thanks
  20. Nov 26, 2012 at 6:49 PM
    #660
    Blackdawg
    Monte
    Wyoming/St. Louis
    :thumbsup:
Thread Status:
